Wierd Clutch Problem
Old Jul 7, 2009 | 10:24 AM
SuckMyVTec's Avatar
Default Wierd Clutch Problem
Ok today when I was driving home my engine started to make this ticking sound. Then whenever I get to a light or a stop sign and I put my foot on the clutch, the car turns off. I have no idea what the clicking noise is but it must have something to do with the clutch because the car keeps shutting down when I hold down the clutch.
p.s its a 1992 EG.
Old Jul 7, 2009 | 10:30 AM
It will idle in neutral, but stall only when you push the clutch? Or does it not idle at all?
Old Jul 7, 2009 | 10:37 AM
It's difficult to envision that pushing the clutch pedal down causes the engine to stall. You more likely have a basic idle problem. Is the CEL ON? Have you cleaned the IACV on the throttle body?
Old Jul 7, 2009 | 10:39 AM
Also when you hear strange noises from the engine, stop and check the oil level immediately before doing anything else.
Old Jul 7, 2009 | 07:49 PM
SuckMyVTec's Avatar
Yes it idles fine. It clicks as soon as I start the car and if I rev it the clicking goes up also.
Old Jul 7, 2009 | 09:01 PM
myexisHOTT's Avatar
sounds like river rats. Yep son, they are a problem sometime. I had a big one in my engine the other day. Went to start up heard some ticking, opened hood and wham right in the nose! son of a gun hit me hard! get some rat poison, should do the trick!
rjdaaa
May 20, 2011 11:32 AM
SuckMyVTec
Jun 24, 2009 06:28 AM
Faramire
Jan 9, 2009 12:37 PM
n8te81
Jun 12, 2006 08:59 AM
carlover
Aug 2, 2005 10:07 PM
