View Poll Results: Which turbo should i use (have both)
TD05H Small 16G
33.33%
TD05HR Evo VIII 16g mr with no twin-scroll mani
33.33%
TD05HR Evo VIII 16g mr with custom twin-scoll mani
33.33%
Voters: 3. You may not vote on this poll
D series questions
Old Jul 20, 2009 | 02:11 PM
kylea24's Avatar
Default D series questions
1. alrite i know this is a newb Q but when i get my built z6 bottom end in will i need a tune?
its a z6 block with vitara's and fjt rods and will be using a sock y8 head, so can i just run it off my p2p with stock injectors until i hook up my turbo kit and get a tune?
2. simple, what are your opinions on what the small 16g is good for? im gonna say 300wph
3. what y8 bottem end parts or inerchangable with a z6
Old Jul 20, 2009 | 02:33 PM
Honestly, I'm not 100% on the tune question. I don't think you'd need a tune, but it wouldn't hurt.
I would say you should be able to see 300whp from a 16g, but it'll depend on exactly what size you're running and a major part will be the engine you put it on (as far as what's been done to it), what boost you're running, and the big one: your tune.
And as far as I know, all y8 parts should be interchangeable with z6 bottom end parts. The bore/stroke and rod length are the same between the engines (75x90mm bore x stroke, 137mm rods). Don't quote me on this, but I believe the head and intake manifold are the only major mechanical differences between the engines (well, that and the y8 has an extra HO2S)
Old Jul 20, 2009 | 02:57 PM
kylea24's Avatar
thanks bro
Old Jul 20, 2009 | 10:35 PM
If you retain stock compression ratio, etc. when you build the bottom end, then you won't need a tune.
Old Jul 21, 2009 | 11:40 AM
kylea24's Avatar
yep it will be differernt, i got 8.64:1 on the calculater with vitaras and fjt rods and the y8 is 9.6:1 stock
Old Jul 21, 2009 | 12:15 PM
kylea24's Avatar
i would really just like to get it droped in and run it with my stock ecu for a week or two then stap on the turbo and get it tuned. saving $400 is always helps too lol
Old Jul 21, 2009 | 01:39 PM
BLaCkSiLo's Avatar
that's exactly what i'm during right now, i just just re-built my vitara bottom with the FJ rods in my z6 and i'm running stock injectors/stock ECU/stock tune. it runs great and the AFR's seem to be normal/the same according to my POS autometer narrowband....as long as you didnt get a BIG cam/major head work
you will be fine with the stock ecu until you get that turbo on there, that's exactly what i wanted to do is break it in N/A then tune with the turbo. good luck man, i know people who have been running for a LONG time that way and no cylinder wash good luck!
oldguy
Mar 17, 2007 01:03 PM
S240161
Nov 3, 2005 08:35 PM
00exinfl
EK Swaps
Mar 28, 2005 10:29 PM
phatek4
Dec 30, 2004 02:09 AM
