Car will not go into gear!!! HELP!!
Old Aug 7, 2009 | 05:26 AM
YONI's Avatar
Default Car will not go into gear!!! HELP!!
ok so about a week ago i was driving down the highway going 90's shifting at high rpms (around 6k, on my stock 1993 si), i got off my exit and was stopped at a light, i could not shift into first, so i shut my car off and threw it into first and started it, I managed to pull it into a parking lot and get it towed back to my house. So far I have tried to bleed the slave, and that didnt work, so i replaced it. then it still wasnt working so I thought it could be the master cylinder, i just orderd a new one.... anyone have some suggestions as to what it could be?!?!
Old Aug 7, 2009 | 05:44 AM
going 90 on the highway... FAIL
why replace all the clutch cylinders? did you have someone LOOK at the slave cylinder and see if it was moving full motion or not? if it was moving fine then its not a hydrolic issue with the slave or master.
and does it only do it in 1st or does it do it in every gear?
Old Aug 7, 2009 | 06:05 AM
kfock05's Avatar
TOKYO DRIFTZ
Originally Posted by YONI
ok well i guess my thread posting days are over then.... thanks everyone!
that didnt last long
Old Aug 7, 2009 | 06:29 AM
YONI's Avatar
It won't go into any gear, and it grinds when I try to put it in reverse
Old Aug 7, 2009 | 06:40 AM
You've probably broken the clutch disk. Even though the hydraulics work, it never disengages because the parts are mechanically jammed together inside the clutch.
Old Aug 7, 2009 | 08:18 AM
YONI's Avatar
it will run if i turn the car off then select the gear
Old Aug 7, 2009 | 08:45 AM
time for a whole clutch swap then. or a new tranny maybe. start saving up
Old Aug 7, 2009 | 08:46 AM
the pressure plate is no good
samething happened to me in my old hatch.....
Old Aug 7, 2009 | 09:27 AM
Do the test that addiction suggested: have someone press the clutch pedal while you watch to see that the slave cylinder piston and lever move. If that is OK, there is a problem inside the clutch-- need to take the transmission out and replace the clutch set.
Old Aug 7, 2009 | 09:57 AM
YONI's Avatar
i only have like 1k right now so is it gunna be more than that to replace the clutch?
