Quick question about squealing A/C belt
Old Aug 28, 2009 | 10:50 PM
Default Quick question about squealing A/C belt
Alright, I really suck at tensioning these damn drive belts. If the belt squeals on startup with the A/C turned on or at low RPMs during the first few starts and stops of a trip, does that mean the belt is too tight, or too loose?
The manual specifies a tension for the belt. How and what would I use to measure this with?
Old Aug 29, 2009 | 06:36 AM
well if it squeals at start up its probably to loose.but just hop under the car and feel the tension on the belt from the bottom see how much it moves. it will probably move quite a bit like 1/4-1/2inch now tighten it up so it only moves about 1/8inch and feels tight....
easy comparison for you is if you have a power steering pump as well feel that belt and compare it.
Old Aug 29, 2009 | 07:43 AM
mundy5's Avatar
+1; my brief experience with belts (i.e. alternator) is that they have to be really really tight for people like me who do not have the proper tools to make them tight. But as addiction says if it squeals upon startup it is probably on too loose. there is some small little device that supposedly measures the tension but I personally only go by the noise.
Old Aug 29, 2009 | 07:47 AM
ya i just go by feel and noise... if it makes noise then tighten it up more until it doesnt.LOL
Old Aug 29, 2009 | 09:49 AM
With the engine off, you should be able to turn the clutch plate on the compressor easily by hand. If it's binding, the compressor is about to seize up.
Tighten the belt just until it won't squeal, too tight is hard on the bearings in the idller and compressor.
Old Aug 29, 2009 | 11:21 AM
Alright, thanks guys.
Old Aug 29, 2009 | 01:20 PM
Turns out it was both the A/C and alternator belts. Got them both tightened up nicely and no more squealing.
mk378... what if the compressor clutch plate turns easily by hand, but in one small section of the 360º turn it is just a tiny bit more resistant, yet still easy to turn?
Old Aug 29, 2009 | 01:31 PM
That's normal. The scroll compressor has a "once around" action inside.
Old Aug 29, 2009 | 01:34 PM
Alright, thought so. I hear the sound of a gas (r134a) moving when it gets more resistant, so I figure that's how it works. If it was never resistant, then the compressor wouldn't be doing it's job, correct?
Old Aug 30, 2009 | 05:18 AM
Right. It doesn't take much force to turn it slowly by hand, but at speed as the pressure builds up it takes horsepower to keep it going.
bobackwards
Jul 19, 2011 06:29 PM
canyonmom
Feb 6, 2011 06:26 AM
Kov
Jun 29, 2006 03:14 PM
THE_CRIPPLER
Dec 6, 2005 08:26 AM
laminatedfrog
Apr 15, 2005 01:23 AM
