Tokico HP
Old Aug 31, 2009 | 03:25 PM
brajj's Avatar
Default Tokico HP
Good or bad? OR better then KYB GR-2?
http://cgi.ebay.com/ebaymotors/TOKIC...Q5fAccessories
I'm looking at these and probably getting some Eibach Springs. Would it be a comfortable ride? Or bouncy as hell?
Also would they be nice with TeinS.
Old Sep 1, 2009 | 01:23 PM
brajj's Avatar
i ordered the Stech springs and the Tokico blues. I was wondering, Its a 1.9inch front and 1.7 back drop, so will it fit with the stock wheels and tires 195/65/14? Thanks.
Old Sep 1, 2009 | 03:39 PM
hamorhead's Avatar
the stock tires should be fine and from what ive heard that should ride pretty good
Old Sep 1, 2009 | 04:21 PM
brajj's Avatar
Thanks =)
Old Sep 1, 2009 | 10:38 PM
Tokico blues are not designed to be lowered, they are OEM replacements like the KYB GR-2's.
Old Sep 2, 2009 | 04:55 AM
hamorhead's Avatar
i had the tokico HP kit which is tokico blues with Tokico red(dont know real name) 1.5" lowering springs up front and 1.25' in the back and it didnt ride like stock
and the blues came factory matched (from Tokico) with those springs
Old Sep 5, 2009 | 12:20 AM
brajj's Avatar
I found StreetSniper's detailed installation of the rear shocks/struts. However i fail to find a detailed one like that for the fronts. Any links to a nice one with pictures?
Old Sep 5, 2009 | 04:47 AM
hamorhead's Avatar
just use google theres a few out thereyou just gotta look
im too lazy to do it for you
Old Sep 5, 2009 | 10:43 AM
http://honda-tech.com/showthread.php?t=1427142
EG is same as EK in the front except for a minor difference with the brake line bracket on the strut, but it doesn't matter because you'll be able to tell what to do with the brake line just by looking at it. It's that simple.
Rear installation is identical. The only difference in the shock itself is that the EK has a wider bracket at the bottom of the shock, which doesn't affect the installation procedure.
Old Sep 5, 2009 | 11:04 AM
brajj's Avatar
Thank both of you very much.
88dxcivichb
Dec 3, 2005 03:49 PM
dmsteele92831
Sep 12, 2005 04:18 PM
glada96EX
Aug 11, 2005 09:52 PM
glada96EX
Aug 11, 2005 08:47 PM
SI_racer
May 19, 2004 12:57 AM
