what x-over frequency should the amp
Old Sep 1, 2009 | 07:15 PM
h.huynh's Avatar
Default what x-over frequency should the amp
kicker zx750.1 amplifier
kicker solo-x 12"
What should the x-over frequency be at.
it ranges from 50hz-200hz. should x-over frequency be at around 100hz?
Old Sep 7, 2009 | 09:18 PM
Stumasters's Avatar
My rule of thumb has always been around 80, and no higher. You could do anything from 65 to 85 without much worry, but when you get above that level, your amp will be trying to send sounds to your subs that they just simply don't want to reproduce. If your rap only, go around 65, if you listen to some rock, try about 80 to 85. This will pretty much work out well for most standard setups.
Old Sep 7, 2009 | 09:25 PM
I'm using 125 Hz... seems to work pretty good.
I was using 78 Hz before though, I just now remembered... probably gonna turn it down to 78 again and raise the gain a little.
Old Sep 9, 2009 | 02:38 AM
EKSiR99's Avatar
80hz for sq 50hz on rap/hiphop hooray
Old Sep 9, 2009 | 12:18 PM
I turned it down to 78 Hz again and it sounds better. I don't really remember why I put it on 125.
wchan3
Jul 19, 2012 01:37 PM
subrata17
May 12, 2008 12:10 AM
subrata17
May 11, 2008 11:29 PM
dacool25
Jan 15, 2007 10:05 AM
cfy30
Oct 13, 2006 01:05 AM
