Best fuel injector's for N/A B20
Old Sep 18, 2009 | 11:01 AM
T-flow cylinder heads's Avatar
Default Best fuel injector's for N/A B20
Whats the best bang for the buck injector's for B20 buit N/A?
Thanks for your replies, T-flow cylinder heads
Old Sep 21, 2009 | 12:28 AM
intenseneal's Avatar
The stock honda injectors should be just fine. I have seen over 200 whp on a stock honda fuel system na. Get your tune done and the tuner will be able to see the duty cycle of the injectors. If they are running close to 100% then get some RC 360cc injectors.
Old Sep 21, 2009 | 05:31 AM
Thats what I was hoping for, thanks. We will see I guess. Thanks, Tflow cylinder heads
Old Sep 24, 2009 | 05:34 PM
hamorhead's Avatar
either that or you could buy my DSM 450's
Old Sep 25, 2009 | 03:39 AM
How much? How old? Whats the condition of the injectors?
Old Sep 25, 2009 | 03:41 AM
GReddy_Civic's Avatar
Snail'n Admin
yea 440s or around that would be plenty.
Old Sep 25, 2009 | 05:39 AM
hamorhead's Avatar
theyre DSM blue tops
they came on 91-93 DSM turbo cars
and check my for sale thread or pm me
Old Sep 25, 2009 | 09:45 AM
what he means is here is his for sale thread you can take a look
https://www.hondacivicforum.com/foru...ad.php?t=78542
they come from a 1991 - 1993 turbo eclipse and will fit on a honda and it is commonly done. and if you need instructions on how to wire them up let me know.
your current fuel injectors are high ohms and these are low ohm thats why it has the resistor box and is easy to wire it up.
Old Sep 26, 2009 | 02:34 PM
Thanks Guy's, PM sent
Old Sep 27, 2009 | 08:46 AM
DSM injectors fit on hondas with some work. Theres the wiring and resistors plus you need to open up the o-rings. They have been know to leak if not done correctly. 440 or 450cc injectors will be a bit much for an NA setup. Like I said go with some 360cc RC injectors if you need mor fuel. But the stock B series fuel system should be fine.
