cd player / turn signal
Old Sep 25, 2009 | 02:52 PM
maxfi3ld's Avatar
Default cd player / turn signal
I have two problems here..
CD Player will not turn on.. I took out the old cd player which was working fine.. wired up the harness for the new one and the new one does not turn on. Took the CD player to Best Buy to test it and it works.. No blown fuses on CD Player or car.. any suggestions??
Right front corner light / turn signal does not work. The left works perfectly front/rear. The front right does it work at all but the rear right turn signal flashes really fast. Looking for info on how to fix that as well. Thanks
95 CIVIC EX
Old Sep 25, 2009 | 03:14 PM
1: did you check your fuse under the dash.
2: replace your bulb its blown
Old Sep 25, 2009 | 03:26 PM
maxfi3ld's Avatar
checked under dash fuse and cd player fuse they are fine
Old Sep 25, 2009 | 04:46 PM
Kehoe's Avatar
I would recheck the harness to make sure everything matches right with stock (red to red, yellow to yellow, black to black to start).
Old Sep 25, 2009 | 05:03 PM
if the fuses are good then pull the radio out and get a test light. your red wire should be hot when the key is turned on, and the yellow should always be hot, also test your ground wire.
Old Sep 30, 2009 | 10:24 PM
KarTuneMan's Avatar
Check fuses under the hood!
Old Sep 30, 2009 | 11:16 PM
maxfi3ld's Avatar
I wired the old cd player back.. plugged it in and no power. Fuses on cd player and under dash are good. Any ideas what is wrong? The clock is on but resets to 1:00 everytime if that helps. I have no idea what is causing the cd player not to work.
Old Oct 1, 2009 | 05:48 AM
^ that confirms that there is a bad fuse you just arent seeing it. your cigrette lighter also doesnt work... recheck your fuses under dash.
Super Mario
Jun 8, 2006 08:12 AM
marcosv827
Aug 8, 2005 05:58 PM
cojodough
Apr 17, 2005 03:02 AM
Super Mario
Feb 23, 2005 10:27 AM
burnoutNshootnos
Dec 22, 2004 10:30 PM
