93 Del sol rear lights not working
Old Oct 5, 2009 | 08:45 PM
Faramire's Avatar
Default 93 Del sol rear lights not working
I changed the bulbs. And the brake lights work. but not the regular lights back there for night And i keep gettin pulled over. i also checked And replaced all bad fuses. what else can It be? cluster don't light up either
Old Oct 5, 2009 | 08:51 PM
it's your combination switch (the switch on the steering column).
Old Oct 5, 2009 | 09:05 PM
PunisherInOKC's Avatar
Does your fuse blow every time you attempt to use the lights?
Also try checking for power at the fuse. If your getting no power to the fuse - combination switch for sure.
Old Oct 6, 2009 | 04:29 AM
the dash lights and tail lights all run on the same fuse,
Old Oct 6, 2009 | 05:14 AM
Faramire's Avatar
the thing is no Fuses were blown. so ilk check that switch
Old Oct 6, 2009 | 12:13 PM
Faramire's Avatar
Can anyone give detailed instructions on how i could get To this switch To replace It?
Old Oct 6, 2009 | 12:29 PM
i think you have to pull off your steering wheel, and underneath your steering column there is 3 screws holding the plastic column cover then pull them off and its right there.
i guess he's talkin about the blinker/headlight switch, but i say it may be your dimmer switch, if you are 1005 positive you checked all your fuses. also did you get a test light and see if your fuse gets power?
Old Oct 6, 2009 | 12:44 PM
Pretty sure that steering wheel removal isn't necessary. Just remove the column cover (3 bolts on the bottom cover) and then that pops apart. Then you should be able to get to the switch.
Old Oct 6, 2009 | 04:05 PM
roadliner's Avatar
Here is the link to the manuals http://hondatech.info/downloads/Auto/Manuals/Civic/ I hope that helps.
Old Oct 7, 2009 | 06:59 AM
Faramire's Avatar
You guys mean this right? i'm going to replace the one on my del sol with the one on my 93 civic(parts/junk car) and see if that works.
http://www.jdmuniverse.com/forums/ho...ht-switch.html
