washer/wiper switch lever problem
Old Nov 7, 2009 | 03:28 PM
oldschool's Avatar
Exclamation washer/wiper switch lever problem
I have a 98 LX sedan. The wiper lever (on the right side of the column), will not go back into the off position. It seems like there is short circuit.
At first the lever would need me to push it up 1/8 inch to set it in the off position, but as of recent I cannot push it back up 1/8 into the off postion. I now must drive around holding the lever in a certain position to keep the wipers turned off.
Should I be replacing the $120 washer/wiper switch, or is there something else that needs repaired or replaced?
I can only think this happened from pulling the lever back hundreds of times to turn on the wiper fluid.
thanks
Old Nov 7, 2009 | 04:02 PM
mundy5's Avatar
yup, had the exact same thing happen to me. went to a junkyard and picked one up for $25. no need to order a new one from honda. i actually pulled mine out of a 5th gen civic and it worked fine.
Old Nov 8, 2009 | 06:10 AM
danomatic93's Avatar
June 2010 ROTM
Check out my DIY for fixing then so you can see the switches inner functionality. I'm thinking that yours is too far gone to fix though...
https://www.hondacivicforum.com/foru...ad.php?t=74275
I have one that is cleaned and ready to go if you want.
Old May 9, 2010 | 09:06 AM
oldschool's Avatar
sent you a message
steve5673
Sep 20, 2013 06:23 AM
jbum
Aug 10, 2013 09:17 AM
95ownermn
Mar 10, 2008 07:55 PM
jbum
Apr 28, 2006 07:57 AM
