need help for remote wire power
Old Aug 3, 2004 | 11:08 PM
joshln's Avatar
Default need help for remote wire power
I try to install the new radio, when I unplug it I make a mistake to touch the remote wire to the ground (of radio). By inspection, I knew that the power of that wire is disappear; there was only 3.5 Volt only, its must have 12 V to order to run ( to open the power of radio). I also check all fusses are fine. Does any one know what is happening? I have Civic 93 4 doors .Thaaaank !!
Old Aug 4, 2004 | 11:35 PM
JayMan's Avatar
Default RE: need help for remote wire power
if there was no power to the unit, then technically the remote touching ground shouldnt have done anything, at most a fuse if connected, but those are ok, chek ur wiring, i have had little issues of remote wires only my switch
Old Aug 5, 2004 | 11:52 AM
joshln's Avatar
Thank Jayman !
I have the voltage meter, so I turned on the key and check the remote wire from the ignition; there is about 3.5 volt (it must have 12 Volt to order to turn on the radio). I checked all fusses were good. Do you know that beside the fuse, it’s anything wrong with this? Thanks!
I got Civic 93 4 doors
Old Aug 15, 2004 | 08:35 AM
eggie75's Avatar
what did you hook up the remote wire to??? did you buy a harness or just splice the wires?
dwalsh77
Oct 11, 2011 07:00 AM
sboarder97km
Apr 21, 2008 07:22 AM
xsdudztx
Aug 14, 2007 05:45 PM
xsdudztx
Aug 9, 2007 07:45 PM
joshln
Aug 3, 2004 11:08 PM
