cleaning under the hood
Old Aug 16, 2005 | 05:42 PM
civicexracer's Avatar
Default cleaning under the hood
my '95 ex has some high mileage 165k (actully thats low for a civic haha) and its old obviously and its pretty ditry and grimy under the hood. i was wondering if u guys could give me some cleaning tips and maybe tell me about some materials that may help lift off that dirt and grime so my engine will look a little more presentable.
Thanks!
Old Aug 16, 2005 | 07:27 PM
ngoti 8tor's Avatar
Default RE: cleaning under the hood
Just use some engine degreaser (no-name works ok for this), and cover any sensitive parts (like air filter) with plastic if it's sticking out (like a SRI or CAI). Spray your warm engine with the degreaser, then after 15-20 minutes, hose it off (car wash sprayer works well here).
Old Aug 16, 2005 | 07:36 PM
mill$civic's Avatar
i would use a engine degreeser and a powerfull hose then use rags and armeral to touch it up, make sure you cover up everything that shouldent get wet such as your alternator,fuse box, sparkplug...ect, or what you could do, is just get out some rags, armeral, and a brush and some degreeser and put the degreeser on and then brush, then wipe off and use some elbow greese if you dont want to use a hose, ether way works good...i clean without the hose
Old Aug 17, 2005 | 08:07 AM
Ford's Avatar
you could always just take it somewhere to get it steam cleaned if its really filthy.
Old Aug 17, 2005 | 08:59 AM
Pete's Avatar
cleaning ur engine bay is a messy job. DONT do it in ur driveway. Go to a self serve carwash. Make sure u bring about 2 cans of engine degreaser.....ive found that the "Citrus" one works best. Cover any wires u can see, cover the battery too. Make sure u cover the dizzy real tight. Spray that stuff on........and i mean lots of it. Let it sit for about 10 minutes, then use the high pressure rinse and powerwash the crap outta ur motor........when ur done.........do it again with the other can..........then start the car up and let it idle for a bit so it can dry. This is how i clean my motor..........and lemme tell u.......u could eat off of it. lol. Good luck
Old Aug 17, 2005 | 10:15 AM
LEVIII's Avatar
ORIGINAL: mill$civic
armeral
Whats this?
Make sure you cover the distrubutor up. I did it in my old Si once and then we left the car wash and the car died and wouldnt restart. Had to buy a lighter from the convenience store and use it to dry the dist.
Ive also heard that some degreasers will cause white spots on aluminuim(sp?) which is pretty much your engine so be careful.
Old Aug 17, 2005 | 12:52 PM
mxs's Avatar
mxs
armeral
Whats this?
Armor-All!
Old Aug 17, 2005 | 12:57 PM
vdog's Avatar
So thats where those white spots on my engine came from! Drats!!
So which degreaser should I use?
Old Aug 17, 2005 | 01:32 PM
Engine Bright
Old Aug 17, 2005 | 02:28 PM
XCM828's Avatar
Come on guys, this is getting kinda out of hand. Post in the right forum.
