Ball Joints problem
Old 04-27-2005, 05:52 PM
Cappelle's Avatar
Default Ball Joints problem
Not sure the best way to handle this problem ball joints bolts are spining inside so i can't tighten them back up. does that mean they are screwed and need new one or is it just a matter of opening it up it sucks because they are all stcuk half on can't back them off really or tighten them...
Old 04-27-2005, 08:50 PM
sacicons's Avatar
Default RE: Ball Joints problem
if the tip is sticking through the nut, you can sometimes use a 4" C-clamp to clamp the tip of the bolt and clamp it down so it wont move, then use an open-ended wrench to turn the nut. if you cant do that, then sometimes you can just press the ball joint into the mounting hole hard enough to seat it enough to turn it.
Old 04-27-2005, 09:09 PM
Cappelle's Avatar
thanks
Perrydise55
06-13-2010 09:44 PM
native
03-11-2008 03:40 AM
branx
02-25-2008 01:23 PM
johnb
02-13-2008 07:10 PM
8891civic
08-31-2006 02:56 PM
Quick Reply: Ball Joints problem
