Rear hub assembly
RE: Rear hub assembly
I should be able to help you in a couple of days when i can get a hold of AllData at school. But i've seen my friend work on the drums on his nissan, he didn't take out the hub if i remember correctly.
Thank you very much, Agent. It does help. Most cars you don't have to remove anything to service the drum brakes, except the drum of course. It makes it easier to remove and install the brake shoes when the hub is out of the way. Maybe I should do a disc conversion in the future. Hmmm...
Jack
Jack
Just as a little side note. When i was changing the axle, the service manual said that it was 22mm, but i ended up having to buy 32mm to take the axle nut off. It might not be the same case, maybe i had the wrong service manual or something, but thats just my experiance. I got this information from AllData, not a service manual however.
Jeremy102579
11-23-2010 04:52 AM
joey20046
02-15-2009 11:11 AM
wheelbearing
06-20-2008 07:23 AM
quickcivicexbj
12-01-2006 12:17 PM
