Squeaking noise in front end
Old 09-23-2006, 10:01 AM
aguynamedchad's Avatar
Default Squeaking noise in front end
Hey everyone. I just bought a 1991 Civic CX and there is a sqweeking noise in the front end. The wheel dosen't chatter and the struts seem fine. Could it be the bushings? When you turn the wheel slightly you can here it, I tried gooping it up but it's still there. Any thoughts?
Chad
Old 09-23-2006, 10:15 AM
AgentofDarkness's Avatar
Default RE: Squeaking noise in front end
When does the noise occur? If it happens when you hit a bump or pot hole then the bushings on the control arms or other suspension parts might be the culprit.
Old 09-23-2006, 10:26 AM
Hi Agento. It happens at slow speeds on bumps, like a speed bump or something. When the car it parked you can here it when you push on the front end, or if you turn the wheel back and forth, or when you come to a complete stop. If you are driving fast and turn the wheel quickly back and forth you can kind of here it in the front end.
Old 09-23-2006, 02:20 PM
My guess would be control arm bushings.
Old 09-27-2006, 05:23 PM
hey, had that problem already and it was lower ball joints. they may seem tight but they get dry.
Old 09-28-2006, 06:29 PM
I will give that a try. I replaced the upper joints and that didn't work. You can really here it driving down the road now. So hopefully thats the problem. Thanks CM
fsanchez323
12-26-2012 03:05 PM
MetAJJicA
08-22-2007 02:12 PM
MetAJJicA
08-15-2007 04:29 PM
apollocriminal
07-08-2007 02:18 PM
k2rad
08-15-2005 02:30 PM
Quick Reply: Squeaking noise in front end
