Steering wheel pulls sometimes when breaking
Old 12-11-2005, 11:59 PM
x2100's Avatar
Default Steering wheel pulls sometimes when breaking
I'm not sure if this is the right place to write this thread, so feel free to move it if i put it in the wrong one.
I put it here because the pulling started when i changed from my stock wheels to 17 inch rims on my 94 ex coupe.
I don't think it's normal, but it doesn't happen often. It happens more frequent if i break a bit harder than normal and the steering wheel will start to pull left and right. I'm sure all the wheels are balanced, so i don't think that would be the problem (but i could be wrong)
The other day it felt like one of my front wheels were going to fall off...
but this pulling only occurs when i brake.. does anyone know what the problem is?
Thanks in advance
Old 12-12-2005, 12:14 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: Steering wheel pulls sometimes when breaking
wild guess...get hubcentric rings for them 17's. also check tire pressure as that will sure as hell do that
Old 12-12-2005, 04:05 PM
ALX's Avatar
ALX
ALX is offline
The tires also have something to do with it. Uni-directional tires like to pull in the direction of grooves in the road, it happens to me all the time. Your car won't get damaged from this unless you loose control of it but it is a common problem with largerr sized wheels.
Old 12-14-2005, 12:44 AM
x2100's Avatar
Thanks guys!
I'll check if i need to get a hubcentric ring.
I checked the tire pressure and it's the same psi
so i guess it might be the uni-directional tires.
It's scarry sometimes, because it feels like I'm about to see a wheel fly off
Old 12-14-2005, 08:45 PM
ya thanks the directional tires thing helped me out, cause i realized my car did that too and then i remembered i had the directional ones, whew. everythings ok. haha.
jpnolan
04-14-2009 11:11 AM
addiction2bass
02-13-2008 07:59 PM
tarboroheel1
02-22-2006 02:01 PM
Remmy
09-15-2005 06:09 PM
vatpitt
05-08-2005 02:12 PM
Quick Reply: Steering wheel pulls sometimes when breaking
