what does these numbers mean
Old 08-22-2005, 12:01 AM
maddawg's Avatar
Default what does these numbers mean
3 numbers on a tire 2xx/40/17 what does the 1st # mean?
and whats the largest 2xx- that a civic sedan 2005 can house?
oh yeah check this place out http://www.hubcap-tire-wheel.com/cus...eels/index.htm
Old 08-22-2005, 12:20 AM
sacicons's Avatar
Default RE: what does these numbers mean
the first is teh width in mm, the second is the percent of the first number that shows the sidewall. so if its 200/50/15, then the 200 is mm wide, 50 means the sidewall is 50% of the width of the tread, in this case, 100mm, and finally, the last is wheel diameter.
205s or 215 should fit, but it depends on lowering, wheel height, and rim offset. also, if you go too wide, they will rub on the inside. or maybe even the outside. 205 is a pretty safe number though.
Old 08-22-2005, 09:09 AM
ORIGINAL: maddawg
Just to add to sacicons answer, the last number is in inches. (I don't know why they've mixed metric measurement with standard measurement)
Old 08-22-2005, 10:14 PM
sacicons's Avatar
oh, good point. that could get confusing
Don1235
10-04-2011 11:29 AM
tallbright
12-27-2010 05:50 PM
h.huynh
07-20-2007 10:07 PM
nightshader
08-08-2005 05:08 PM
Replacement
06-17-2005 06:48 PM
Quick Reply: what does these numbers mean
