Powerless Window.. :/
Old Oct 11, 2008 | 04:44 PM
clic's Avatar
Default Powerless Window.. :/
(1999 Honda Civic Ex, coupe)
The passenger window was working fine until i decided to turn the car off. Now the window doesn't make any noise at all. My biggest concern is all the rain i have been getting with my window now partially stuck down.
I think it was a faulty fuse or the motor went out but the left window still works fine.
I looking to repair this myself with a little guidance from this wonderfull website.
1. Can i repair this by myself
2. What tools will i need
3. How long will this take
4. Do i need to possibly buy a new fuse or seperate part.
Old Oct 11, 2008 | 04:49 PM
Start by checking whether fuse 10 under the dash is blown. Yes, you can definitely fix this problem yourself.
Also check whether the main switch is turned OFF.
Old Oct 11, 2008 | 05:11 PM
clic's Avatar
i certainly will. is the main switch located in the same area as the fuse. Trying to take a good mental picture. : D
Old Oct 11, 2008 | 05:15 PM
Originally Posted by clic
...is the main switch located in the same area as the fuse...
No, the main switch is located near the window switches on the driver's door. It toggles to ON or OFF. Make sure it is ON.
Rattlin_Steele
Jun 6, 2011 10:45 AM
eric2english
Jan 16, 2010 09:54 PM
AGibney
Dec 29, 2009 05:59 PM
NTX
May 4, 2004 07:12 PM
