another DIY led glow bottle cup holder ;)
Old Apr 27, 2007 | 06:06 PM
  #21
Default RE: another DIY led glow bottle cup holder ;)
well depends on what type of amplifier fuse ya use thiers pleanty of types...
but i just use a typical fuse box fuse.....
mostly the add-a-circuits from autozone.
tho i dont have it wired up in the car YET.... my only problem will be finding a location to mount my new switch... cause my old switch location now houses my fog light switch
i still have to wire in a few diodes as well so i can select if i want it to flash or just solid..... but i still need to buy a switch..... so ill just redue it later on....
Old Apr 27, 2007 | 07:48 PM
  #22
BrianT's Avatar
that looks really good.
Old Apr 28, 2007 | 05:15 AM
  #23
Chaos's Avatar
Ive been contemplating doing something similar with my custom boot install. Im getting some fuel bottle mounts in my boot for my fire stick with lights in them like this. Its a good look.
Old Jun 17, 2007 | 10:18 PM
  #24
ncpaintballer66's Avatar
im ordering the LED's today so that i can do this sick mod... but i have one question... what isa good inline fuse... and how many amps does the fuse need to be... im doing mine in red and ill have pics up ASAP.. ill include gatorade pics so you can c how it looks with red gatorade with red LED's
Old Jun 18, 2007 | 01:34 AM
  #25
well leds dont use much power at all.... any type of inline fuse will work fine... and for fuse rating id say 2.5 or 5amp
Old Jun 18, 2007 | 08:30 AM
  #26
civic96lx's Avatar
can you show a pic of where you grounded the wires??
Old Jun 18, 2007 | 01:20 PM
  #27
ground wires can be grounded to anything metal under the dash... nothing specific realy...
im still to lazy to instal this cupholder in my car.LOL
i just got my cheap @ss used rims so im gonna spend the next day sanding and painting them up then ill work on my vtec valve cover and then instal this cupholder... i got alot of stuff to do before this saturday!
Old Jun 18, 2007 | 08:31 PM
  #28
ORIGINAL: civic96lx
if your putting the wires in your cup holder then when you run the wires to a switch on your arm rest like i did just run the ground wires to a bolt under the arm rest... like the ones that hold your e-brake on your frame... thats what i did and it worked out grate and saved a lot of wire sence you dont have to run it very far...
Old Aug 15, 2008 | 11:02 AM
  #29
nineteenninetynine's Avatar
there are two wires coming off the lights which is power and which is ground red or black?
Old Aug 18, 2008 | 07:18 PM
  #30
sde780's Avatar
red would be positive, black is negative or ground
