i get shocked!!!!????
Old Nov 10, 2008 | 05:57 PM
dito.... has nothing to do with the stereo... just static electricity..... either instal one of those grounding straps or just get out of your car a different way.....
grab the door and THEN step out and hit the ground with your foot....
in my old truck i almost ALWAYS got shocked from geting out of my it until i relearned how to get out of the truck differently, then i never had a problem again.....
Old Nov 10, 2008 | 08:19 PM
eloplayspolo's Avatar
haahahah Do u shuffle your feet while u drive sir?
Old Nov 16, 2008 | 04:24 PM
jpnolan's Avatar
Old Nov 17, 2008 | 12:24 AM
brokenarmboy19's Avatar
lol this can be dangerous while refueling (unless you live in oregon, we dont pump our own gas) it honestly can be a fire hazard
Old Nov 17, 2008 | 07:41 AM
if raw wire is exposed anywhere touching your chasis, thats prob why ur getting shocked. especialy if u went thru your firewall and then pulled your power wire tight. when u pulled the wire thru firewalls sometimes it will slides open the shielding and u get shocked.
Old Nov 19, 2008 | 05:14 PM
ltkenbo's Avatar
Yeah def static electricity, happens to me too. Even if there was a bear wire exposed why would he get shocked just by touching the surface of his car? Electricity takes the path of least resistance and the metal of the car to the negative side of the battery is a lot more conductive that the path from your hand to nowhere.
Old Nov 19, 2008 | 05:24 PM
ya the bear wire HIGHLY UNLIKELY!!!!
most power wires have a very thick jacket and if it shorted out all the time he would constantly feel a tingling not just a short shock. LOL plus the fuse should blow....
Old Nov 19, 2008 | 08:53 PM
bigmikew1's Avatar
it happens to me too lol
Originally Posted by jpnolan
is that metal? wouldnt that be annoying hearing that scrape against the ground?
Old Nov 19, 2008 | 09:16 PM
your body constantly has an electrical charge running thru it. if a wire has small enough charge and u touch that piece of metal it will create a large enough charge to notice... ie. a shock
Old Nov 20, 2008 | 01:42 AM
its a metal rod internally that is surrounded by a rubber coating... so the coating will keep it from making any noises plus while driving it will be held up by the wind some.... no need to trim to exact fit because it will wear just fine...
BOO- your wire theory
Tater
Jan 29, 2007 07:58 PM
bobbytonic
Aug 28, 2006 10:40 PM
Fejery4491
Aug 4, 2006 06:27 PM
Forty04
19
Mar 30, 2005 02:43 AM
