exhaust manifold and cat advice
Old Oct 6, 2008 | 06:28 PM
davidt222's Avatar
Default exhaust manifold and cat advice
I need to replace by '98 DX exhaust manifold and cat. converter. I believe I have the D16Y7 and I would like to save as much money as possible without sacrificing quality. Any suggestions on where to get OEM or suitable replacement to fit my needs? I prefer bolt on so I can do it myself.
Old Oct 6, 2008 | 07:08 PM
Old Oct 6, 2008 | 07:11 PM
davidt222's Avatar
Originally Posted by RonJ
I would like to do better than $420. This seems rather steep to me.
Old Oct 6, 2008 | 08:46 PM
For general header/exhaust mani advice: https://www.hondacivicforum.com/foru...ad.php?t=53044
there are only a few compnaies that make an aftermarket header/high-flow cat combo for the y7. If you just get an EX header (which is much easier to find and cheaper too) along with a universal cat, just bolt the header on and get the cat welded somewhere in the exhaust so you stay emissions legal. From there, either get an 02 sensor extnesion for your secondary sensor from www.passwordjdm.com or get an o2 simulator to clear that CEL you'll get since the secondary o2 sensor won't reach the new location of the cat. If you're planning on getting a cat-back exhaust, try and just find an EX cat and an EX cat-back exhaust from the same year and then no welding will be involved. Just bolt on the header, cat and exhaust (in that order) and you'll be set.
Old Oct 7, 2008 | 04:49 AM
davidt222's Avatar
So do you think getting the EX header, cat and cat-back exhaust would be cheaper than getting the DX manifold/cat? Also, if I were to go with the EX header/cat/cat-back, do I still need the O2 sensor extension?
Old Oct 7, 2008 | 09:19 AM
Tiran's Avatar
Switching to an EX or D16y8 setup will not be cheaper. I am pricing it out now and even using Ebay and the cheapest parts it would still cost in excess of 500 dollars.
Here is what you need to justdo it as cheaply as possible
NEw catalytic converter and manifold 1
New catalytic converter and Manifold 2
I found 2 under 200 in 10 seconds on Ebay, so just look and see what you can find.
Old Oct 7, 2008 | 09:35 AM
davidt222's Avatar
Thanks, Tiran. That looks like exactly what I need! Can't wait to deal with these rusty bolts
Old Oct 7, 2008 | 10:00 AM
If you live in California, at least one of the two items will not pass emissions inspection there.
Also verify that your current O2 sensor will work seamlessly with the aftermarket manifolds because the need to purchase a new O2 sensor may make these units not seem like such a good deal.
Old Oct 7, 2008 | 11:15 AM
Tiran's Avatar
Yeah, like I said, look around, don't necessarily use ebay and make sure everything will match and line up.
It sucks to pull something apart and then realize your new part is not what you need.
Also, why do you need a new manifold? is it leaking? not passing emissions? too rusty for your liking? these are all important facts. As well, what is the condition of your down pipe and the rest of your exhaust system?
Old Oct 7, 2008 | 03:36 PM
oh dude i didn't even realize you wanted OEM replacement.....a Megan header being like $130, an OEM cat being like $140, like $25 for the custom flange you'll need and then the o2 extnesion like $30, you're looking just over $300, or you could go here for an exact replacement for slightly cheaper: http://cpwstore.carpartswholesale.co...94966218&Nty=1
Sorry for the confusion, i thought you wanted aftermarket man. I guess if you wanna drop like an extra $50 - $100, you could convert the whole exahust sytem to EX and get some gains, or you can get that OEM replacement from that site, up to you.
