Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 09-19-2005, 09:40 PM
XCM828 XCM828 is offline
Default Solved problems. Check here first.
This is a list of various problems people have had solved by HCFers. Before you post, skim these lists because somebody might have already fixed your problem. If you have had a problem solved in any of the forums, please PM me and I will add them to the list. Enjoy!
General
1. Cranks but won't start: http://www.hondacivicforum.com/m_97980/tm.htm
2. Intermittent starting and stalling problems: http://www.hondacivicforum.com/m_82668/tm.htm
Cooling, Heating, and A/C
1. Water temp. needle moving up and down: http://www.hondacivicforum.com/m_91868/tm.htm
2. A/C smell: http://www.hondacivicforum.com/m_92756/tm.htm
3. Overheating problems: http://www.hondacivicforum.com/m_82002/tm.htm
4. A/C vent rattle: http://www.hondacivicforum.com/m_79630/tm.htm
Fuel and Exhaust
1. Car bogs during acceleration: http://www.hondacivicforum.com/m_96852/tm.htm
Engine Electrical
1. Replacing distributor: http://www.hondacivicforum.com/m_98965/tm.htm
2. Car starting problems: http://www.hondacivicforum.com/m_81093/tm.htm
3. No spark: http://www.hondacivicforum.com/m_82923/tm.htm
4. Car bogs in lower RPM band: http://www.hondacivicforum.com/m_133369/tm.htm
Transmission
Clutch and Driveline
1. Grinding noise in axle bearings: http://www.hondacivicforum.com/m_94069/tm.htm
Brakes
1. E-brake light flickering: http://www.hondacivicforum.com/m_97413/tm.htm
2. Brake noise (with sounds clips): http://www.hondacivicforum.com/m_89552/tm.htm
3. Rotor screws: http://www.hondacivicforum.com/m_155.../tm.htm#155685
Suspension and Steering
Body
1. Removing bumper cover: http://www.hondacivicforum.com/m_98838/tm.htm
2. Trunk lever not opening trunk: http://www.hondacivicforum.com/m_96511/tm.htm
3. Water under driver's left foot: http://www.hondacivicforum.com/m_66590/tm.htm
4. Water under passenger seat: http://www.hondacivicforum.com/m_58633/tm.htm
Chassis Electrical
1. Resetting SRS light: http://www.hondacivicforum.com/m_99522/tm.htm
2. Aiming headlights: http://www.hondacivicforum.com/m_94836/tm.htm
3. Window rolls up slowly: http://www.hondacivicforum.com/m_79971/tm.htm
4. Stereo not working after power disconnected: http://www.hondacivicforum.com/m_89985/tm.htm
5. Window comes off of track: http://www.hondacivicforum.com/m_124507/tm.htm
Random
1. Door froze shut: http://www.hondacivicforum.com/m_134084/tm.htm
__________________
And for all you VTECHers out there: Please Click
HCF Map!
Old 09-19-2005, 09:50 PM
Remmy Remmy is offline
Default RE: Solved problems. Check here first.
If it looks good and understandable it will be.
__________________
Old 09-19-2005, 10:24 PM
mxs's Avatar
mxs mxs is offline
oh god... I have a bunch for you
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 09-19-2005, 10:34 PM
Please PM me the links! Skimming all of these posts is going to be a bitch so please send me links to any problems you had solved in any of the forums.
I'm tired, so I'll work on it more tomorrow. PM me links please!
__________________
HCF Map!
Old 09-20-2005, 09:56 PM
Ok so now you guys get the basic idea of what I'm aiming for. PM me all your links to problems you've had solved (doesn't have to be in just the General Tech forums) so we can get this list going.
__________________
HCF Map!
Old 09-20-2005, 10:07 PM
ngoti 8tor ngoti 8tor is offline
Great idea, XCM.
Old 10-02-2005, 02:51 PM
Civic89Hatch Civic89Hatch is offline
My civic isnt gett any spark, replaced the distributor and the cap im just not gettin any power to the distributor all the fuses check out ok
Old 10-02-2005, 03:05 PM
ohbiskits ohbiskits is offline
Send a message via AIM to ohbiskits
ill bet your timing belt popped
Old 02-15-2006, 07:30 AM
slick0899 slick0899 is offline
Hey Guys,
Did complete tune-up on 2000 Civic. Replaced plugs, wires, cap & rotor.
Drove down the street and engine light came on. Ran a little rough too.
Checked out wires with Ohm meter, everything checked out ok. What might have I done to cause this problem. Help, this is my only car.
Ken
Old 01-15-2007, 08:04 AM
therivler1 therivler1 is offline
Hey OP,
Solved my squeaking problem:
http://www.hondacivicforum.com/m_336660/tm.htm
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
