Foggy Headlights
My headlights are all gross. They have like a film on them that I can't get off. I think it might be like hard water but I am unsure. A friend told me turtle wax would but I tried Wolfgang and no luck.
RE: Foggy Headlights
I've heard that aluminum polish should do the trick. If not, take some very very fine sandpaper. Get plenty of water on it, and sand the headlights very lightly. Be extremely careful, if you try that.
u take like 1000 sand paper and sand them down (wet sand) really good...then polish them back...with a buffer and some polish
I really don't want to use the sand paper because the film is not all around. It is sparsely covering it. I will try aluminum polish.
You can also try toothepaste......the white kind, not the gel.
turtle wax does work try that...rub it in good and buff it off
ORIGINAL: civic96RB turtle wax does work try that...rub it in good and buff it off |
Id just do the ole 1-2 replacement
is the fog inside or outside the headlight...cause if its inside i got the same problem...n i have no idea how to get that fixed
It is on the outside. One guy said to vent his headlights he drilled three really tiny holes in the headlights. Not something I would do but it might make sense to you.
| All times are GMT -8. The time now is 07:13 AM. |
