Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 11-23-2004, 08:27 AM
djlazy djlazy is offline
Default mounting amp in boot?
Ive just got my civic and im about to fit my sound system in it. Where does every1 mount their amps? Ive been told the back of the seat is the best place but i cant put it there as i need the space when the seats are folded down. any suggestions???
Also what do you use for the grounding point?
cheers every1
Sponsored Links
Old 11-23-2004, 09:09 AM
no9t9 no9t9 is offline
Default RE: mounting amp in boot?
i also mount my amp on the back of the seat but if you cant put it there, you can always mount it to the back of your box for the subs. Are you getting subs?
Edit: I ground my amp to a bolt that is under the rear seats. All you need it to attach the ground to an un painted (bare) metal surface of the car.
__________________
Free Ipod for Canadians too!
http://www.mp3players4free.com/default.aspx?r=161340
$275 Cash - complete 1 free trial offer, refer 5 friends
Old 11-23-2004, 10:51 AM
im guna be running 2 10" subs and was thinnk of mounting the amp 2 the back but the vibrations might mess it up a bit???
Old 11-23-2004, 03:37 PM
I don't think it will be a problem. I know a lot of poeple who mount them to the box because it is easier to take out when they have to put stuff in the back. I never heard them complain about their amps...
Also, if you think this is not a good idea, you can mount it on the SIDE of the boot. But this means you will have to make some kind of mounting apparatus. Usually, some wood board will do but it won't look pretty... if you want it to look good ... that's more work. Probably easiest to take it to a custom shop. I don't know about you, but I'm not very good with Carbon Fibre.
__________________
Old 11-23-2004, 06:18 PM
sacicons sacicons is offline
if vibration hurt an amp, would they last long in anyones car? probably not. mounting it on the box is a good idea if you want to keep it all compact.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 11-26-2004, 12:40 PM
Got my civic yesterday and have just fitted my soundsystem. I sound deadened the base of the boot and will be puttin a proper install for the sub soon. I decided to screw the amp to the back of the seat as it is the most secure way. I will soon be amping up my front components. Do you recommend speakers in the back aswell? Heres a pic so far:
Bit messy not sure what to do with all the wires without ripping up the back of the seat!!
Old 11-26-2004, 09:37 PM
Vovka86 Vovka86 is offline
Yea SONY all the way.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
