RE: mini me...91
if you have DPFI you need to wire up for MPFI, and you would need to wire in the Vtec, i recomend getting the intake manifold, dissy, head(of corse), and exhaust manifold, i was going to use the same head and hall but went with the DOHC ZC swap instead, you will basicly be doing the MPFI swap+ adding vtec, i know you have to take the oil squirt jet out of the top of the block when you have the head off, thast about all i know.
hope it helps.
__________________
I saw a Toyota Celica Si-R......
