Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 10-13-2005, 11:07 PM
91crx_87 91crx_87 is offline
Send a message via AIM to 91crx_87
Default whats a good tranny
i have a b18a1 and need to know what transmission would be good to replace the stock one with.
[IMG]local://upfiles/5651/AAC5DF34C9294D74A05DD9B229899C95.jpg[/IMG]
__________________
91 crx b18a1 engine swap, stage 2 cams, header back exaust, coil overs, intake, full camber kit
Sponsored Links
Old 10-14-2005, 09:13 AM
amg6975 amg6975 is offline
Default RE: whats a good tranny
Will the one from the Type-R (C5) bolt up? I don't know the numbers but that one has a LSD diff. too. Should be the closest ratios too.
__________________
Old 10-14-2005, 09:31 AM
im not sure if it will bolt up or not, does anyone know exaclty? but the LSD would be nice.
__________________
Old 10-14-2005, 11:51 AM
Kappa22 Kappa22 is offline
I'd go with a B16A tranny. The shorter gear ratios will give you better acceleration. However, if you drive on the freeway a lot, you'll find that cruising at ~70 mph will put your engine up close to 4,500 rpm. This isn't a bad thing, but some people get scared...
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 10-14-2005, 01:48 PM
2000Ex 2000Ex is offline
Or annoyed by the gas mileage/ noise while cruising. My tranny is at like 3-3.5 at 70 and the engine makes enough noise.
Who's car is that in your avatar?
__________________
Turbo December 2005
Merry frickin Christmas
Old 10-14-2005, 03:17 PM
so running at about 4.5 to 5 grand wouldn't hurt it?
__________________
Old 10-14-2005, 06:28 PM
sacicons sacicons is offline
youll want either another tranny form an LS, because of the gas mileage and lower cost of the tranny itself, or an early SIR1 b16a tranny with an LSD. more expensive, but the lsd is very nice to have.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
