10-28-2005, 10:07 PM
Wet Clutch?
Ok, I'm familiar with motorcycle clutches where we basically have two kinds: wet and dry. Wet clutch shares the same bath of oil as the transmission, and the rest of the engine too. What about Civics, how are our clutches lubricated, the same way?
10-28-2005, 11:06 PM
RE: Wet Clutch?
i'd say automatic trannys are wet clutches & standards are dry clutches
__________________
[IMG]
[/IMG]
10-30-2005, 07:24 PM
RE: Wet Clutch?
If you're lubing up your clutch, you won't be going anywhere fast...
Autos don't use "clutches," per se; they use torque converters.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
10-30-2005, 07:26 PM
RE: Wet Clutch?
yea and they suck.
honda 5 speed uses 10W 30 motor oil
auto uses tranny fluid
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
10-30-2005, 07:28 PM
RE: Wet Clutch?
But the 10w-30 doesn't actually ever touch the clutch... All trannies need lubrication, but clutches need friction.
__________________
10-30-2005, 07:30 PM
RE: Wet Clutch?
I thought he wanted to know what to put inside to lube it up.
__________________
10-30-2005, 08:21 PM
RE: Wet Clutch?
No, I'm asking what lubricates the clutch in our cars--not the transmission itself.
10-30-2005, 08:26 PM
RE: Wet Clutch?
Nothing. A lubricated clutch disc would not be able to generate friction, and therefore somewhere in the neighborhood of 0% crank power would be transferred to the wheels.
__________________
10-30-2005, 08:27 PM
RE: Wet Clutch?
yea it wouldnt be able to "grab" the gears
__________________
10-31-2005, 12:49 AM
RE: Wet Clutch?
Quote:
ORIGINAL: Kappa22
If you're lubing up your clutch, you won't be going anywhere fast... Autos don't use "clutches," per se; they use torque converters.
Actually auto's do have what is called "clutch packs".
__________________
Greddy Turbo w/IC
HP Dual Stage Boost Controller
E-Manage
310cc
MSD
Golden Eagle Block Guard
ARP 9:1 Pistons
ARP Head Studs
H-beam rods
ZEX Street/Race Cam
Stage 4 clutch
Quaife LSD
Aluminum Flywheel
Hasport Motor Mounts
Flow
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
