Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
ZC motor in a 4 gen
  Printable Version
Honda Civic Forums >> Your Ride >> Engine & Internal >> ZC motor in a 4 gen Page: [1]
Login
Message << Older Topic   Newer Topic >>
ZC motor in a 4 gen - 12/11/2004 12:52:27 PM
koolguy234
Status: offline
I was looking to get a fourth generation civic and if I couldn't find an SI version I wanted to do a motor swap. I was reading around a I saw that ZC and D16Z6 motors easily swapped into a 4th gen chassis. I couldn't find a D16s for sale on the web but I found plenty of ZC motors. Are ZC motors worth swapping are parts easily available in case it breaks down. Also are there any performance mods for sale that will fit the motor.
Post #: 1
RE: ZC motor in a 4 gen - 12/11/2004 4:19:23 PM
Kappa22
Status: offline
ZC motor swap is definitely worth it for the money. You can pick up an imported engine for under $600. They bolt right into 4G Civics (same mounts), and they use the same transmissions (you probably want to get an Si or at least a DX tranny for better gear ratios). Also, you will want to find an ECU from an 88 or 89 Integra 5-Speed (don't use the stock ECU). There are a few electrical modifications that need to be done, but they are very simple. If you end up getting a 4G Civic with DPFI, there are some slightly more complicated steps involved in converting it to MPFI. As for parts, there are a lot of sites out there with parts lists for ZC motors. Basically, they just use a lot of parts from a bunch of different Honda engines. I have a list somewhere, but I'm not sure where it is. I've done a couple ZC swaps, both for me and for a friend, and they are very simple. As for aftermarket performance, most performance parts for D16's will fit right onto the ZC, so that is definitely not a problem.
If you have a lot of money to spend, and you want a bigger performance boost, the B18C5 is about as good as it gets, but be warned: they are quite pricey. If you want an inexpensive engine that is still very buildable, the ZC is for you.
< Message edited by Kappa22 -- 12/11/2004 4:20:04 PM >
_____________________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
(in reply to koolguy234)
Post #: 2
RE: ZC motor in a 4 gen - 12/11/2004 9:43:30 PM
koolguy234
Status: offline
If you find that list with the parts sites on them could you give them to me I would appreciate it.
(in reply to Kappa22)
Post #: 3
RE: ZC motor in a 4 gen - 12/11/2004 10:13:55 PM
koolguy234
Status: offline
What kind of fuel injection systems do 4th gen civics beside the SI use. I read an article in Sport Compact Car where they swapped a D15 for a B18 and they had to switch from multi port to direct port. Would I need to do the same thing if I switched to the ZC. Is the wiring complex? And what wiring would I have to do to make the switch.
Post #: 4
RE: ZC motor in a 4 gen - 12/11/2004 10:21:59 PM
koolguy234
Status: offline
Could I use the stock drive shafts with the ZC engine and transmission or would I need to Change them.
Post #: 5
RE: ZC motor in a 4 gen - 12/12/2004 1:01:44 AM
Kappa22
Status: offline
In loose terms, Honda MPFI is direct port. The only other type of injection system on 4Gs is DPFI (dual point fuel injection). This is where there are two aerator type injectors mounted in a vertical throttle body, and the fuel-air mixture is generated in the throttle body and sucked into the cylinders. Direct port is usually reserved for after-market manifold setups. Basically, in order to convert to MPFI, you have to add some pins to the ECU harness for the other two cylinders and a couple sensors, reverse two wires on one of the distributor plugs, and swap the ECU with an 88-89 Teg 5-Speed one (PG7). I can give you directions if you want. It's pretty simple stuff.
The ZC can use ANY stock 4G Civic tranny (you can just leave the tranny, clutch, and axles in there). Ideally, you want an Si tranny for its closer gear ratio. I like the DX tranny, since it actually has a 5th gear for freeway cruising.
If you have any more questions, feel free to ask.
Post #: 6
RE: ZC motor in a 4 gen - 12/12/2004 10:42:34 AM
koolguy234
Status: offline
Does the ZC have multi port injection or does it have throttle body injection.
Post #: 7
RE: ZC motor in a 4 gen - 12/12/2004 5:53:12 PM
Kappa22
Status: offline
ZC's have multi-port.
Post #: 8
RE: ZC motor in a 4 gen - 12/13/2004 12:53:28 PM
koolguy234
Status: offline
will the fly wheel from the ZC mate to a 4th gen tranny.
Post #: 9
RE: ZC motor in a 4 gen - 12/13/2004 2:12:16 PM
Kappa22
Status: offline
yes, it will, provided it's from an Si or DX
< Message edited by Kappa22 -- 12/13/2004 2:35:24 PM >
Post #: 10
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414235
remmy11161
fiirkan10505
mill$civic8468
marty8273
mxs8006
fliphkd7207711
nail i3unny7705
sacicons7675
addiction2ba7336
New Vendors
K&N Engineering, Inc.
