HondaCivicForum.com
-   -   whistling sound (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/whistling-sound-12384/)
Mark Nov 4, 2005 09:52 PM
whistling sound
well i have an intake and ive heard that sometimes those create like a sucking sound. but ive had it for quite some time and tonight i went out and the car seemed to make a whistling sound that grew louder and quieter with the rpms. i cant tell if its the engine or not. i just installed new speakers amp and head unit too and thats the only thing that has changed. so i dont know if it could be the amp picking something up or what.
absoulute Nov 4, 2005 09:56 PM
RE: whistling sound
you might be pickin up engine noise from a bad ground turn the stereo off and see if u still get it ......if not move the ground wire... or the rca's are next to the power wire which isn't good...
Mark Nov 4, 2005 10:10 PM
RE: whistling sound
grounded head unit or grounded amp?
meangreen Nov 10, 2005 12:09 AM
RE: whistling sound
sounds like the power wire is too close to the rca jacks.
Roost3r Nov 10, 2005 12:25 PM
RE: whistling sound
ORIGINAL: meangreen
^^^^^^^^ Ding Ding Ding
did you wire your system yourself or did someone eles? whoever did it probably put the Power(Big wire) and RCAs(white and red) to close together which means you will pick up the exact noise you are talking about. You need to keep them as far away as possible..try putting them both sides of the car. your noise should go away.
Pete Nov 10, 2005 03:34 PM
RE: whistling sound
or u could get a nice set or RCAs and it will stop. I have my power, remote, bass, AND RCAs all going down the same side.......no noise......then again my RCAs werent 10$ either.
Roost3r Nov 11, 2005 02:52 AM
RE: whistling sound
hehe..well most of them are poor
