Exactly whats the difference between caermaic and stainless steel header???? I noticed that ceramic is much more cheaper than stainless steel. Which one would you recommend???
bottom line, ceramic is better performance and stainless looks better
Edit: sorry my mistake.. u were asking about chrome before. Stainless and chrome are pretty much the same. they don't perform the same as ceramic in heat isolation.
yeah, ceraminc is usually better. but some of the high quality headers have stainless steel with a ceramic coating inside. in that case they are about the same, but the SS looks cool once it heats up and it turns a lot of colors.
__________________
Thanks for the tip. I guss ill get a dc sport 4-2-1 ceramic header then but there is one more thing i need to know. Whats the difference between 1 and 2 piece header??? Which one would you recommend?
a 2 piece mightbe easier for you to install on your own. but if you have a buddy or 2 aroudn then the 1 piece will be easy too. will run less of a risk of an exhause leak with a 1 piece also
__________________
gone but not forgotten 98 civic lx sedan
RIP 3/23/05
current garage
04 nissan armada le
01mustang gt
blown, intercooled, and cammed
04 acura tl
98 4runner
yeah, 2 piece is way easier to install. but i like one piece better, less weight and less bolts. i hate those stupid exhaust bolts. and put antisieze compound on exhaust bolts.
__________________
