alright I wasn't sure what to put this under but I'll make it fast and easy
I got soap, water(hose), rags, sponges, and window cleaner, tire cleaner and so on...
I'm cleaning my boss's dump truck (lil red) cause he's sorta a clean freak anyway
he tells me top to bottom, heres what I do
Spray down the entire truck
Mix soap and water in bucket, and sponge section by section, spraying the soap after soon afterwards
and clean all the tires, wheels, mirrors, glass and so on
Did I do it right? I used to have a squeeige but my boss has alot of lil kids, and they take stuff and **** with it, and whenever i let it dry it leaves marks, and if i use a paper towl or cloth it smears, I don't know it's hard to explain, do this make sense to anyone? I gotta go soon so ANY and ALL help is greatly appericated thanks
dry it with a soft, clean towel as soon as you are done washing it, that will keep the streaks down. and make sure you are using car soap, not dish soap, shampoo, or handsoap. it has to be car soap.
__________________
ngo, he does let me drive them around, but not on any major roads, just side roads/niebghorhood's, anyway sac's tip seemed to work, or mybe it was my mind playing tricks on me
umm if its the ones im thinking about there about $18 (canadian), i wouldent get tho for your boss, give your boss the crap $2 ones and save the good stuff for yourself
