Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 11-27-2005, 03:38 PM
maximummax001 maximummax001 is offline
Default Shifter is loose?
I just got a nice 98 coupe with a 5 speed with an odd shifter problem. When I engage the gear, all is normal, but after the shifter is in gear, the stick has a lot of lateral movement. Moving the stick around does not cause the tranny to pop out of gear or anything, but it makes it a little tough to know where you are. Let me know if anyone knows how to fix this.
Thanks!!!!
Old 11-27-2005, 04:12 PM
dj_ipirate dj_ipirate is offline
Default RE: Shifter is loose?
seems normal to me.... about how much is it moving? little jiggles or make strippers look like they are standing still jiggle...
__________________
nice mustang... sorry about your penis.
Old 11-27-2005, 07:18 PM
like 4 inches jiggle. It's kinda weird, every other shifter I've used (not that many mind you) was a little different. If it's normal then it's normal, but hey... seems weird to me.
Old 11-27-2005, 07:54 PM
mxs's Avatar
mxs mxs is offline
You might want to look into a set of poly shift bushings. You can get them pretty cheap and install them yourself. Read reviews here: http://www.hondacivicforum.com/fb.asp?m=119209
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 11-28-2005, 08:24 AM
Has anyone actually experienced this problem before?
I am not sure about the bushings as far as being able to cure this problem. It seems really cheap and easy so I'll probably do it anyway, but it doesn't see like a loose bushing could cause this.
Thanks for the links, they will help a lot. I'll probably order the parts today from summit and throw them on over the weekend.
thanks for the advice... if anyone has any other ideas I'd love to hear them.
Old 11-30-2005, 11:08 AM
my 88 hatch does that... but the whole engine and tranny shakes with it... not a good sigh.
__________________
Old 11-30-2005, 11:14 AM
I guess my motor and tranny are not moving, so I am going to throw bushings into it. Nobody has told me whether this will actually work but we're hoping for the best.
Old 11-30-2005, 11:17 AM
your problem is odd... good luck with that.
__________________
Old 12-10-2005, 11:05 AM
In case anyone still wants to help, I just got finished throwing the bushings in and the shifter still moves the same amount laterally while in gear... it seems that the bushing on the end of the shifter itself is mooshy. Any ideas?
Old 12-10-2005, 11:58 AM
ngoti 8tor ngoti 8tor is offline
Yes, I know who can probably help you.
Go to this link and either post or PM (probably get faster results) Paul, and he can ask one of his technicians for the answer.
http://www.hondacivicforum.com/m_123.../tm.htm#123776
I have asked Paul a few questions, and he came up with the answers for me and even emailed me some pics from the service manual.
They're one of HCF's sponsors and he is a great asset to this forum.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
