Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
ECU F.A.Q's
  Printable Version
Honda Civic Forums >> Your Ride >> ECU Tuning & Fuel Management >> ECU F.A.Q's Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
ECU F.A.Q's - 12/5/2005 12:11:33 PM
Marty
Status: offline
Marty's photo gallery
What is obd1, obd2, obd2b, etc.?
OBD = On-Board Diagnostics.
92-95 Hondas are obd1
96-98 Hondas are obd2
98-00 Hondas are obd2b
What ecu do I have?
D16Y8 - P2P (comes in an obd2 and obd2b variety)
D16Z6 - P28
D16Y7 - P2E
Should I Chip my ecu?
If you have an obd-2 (96-00) then you can not chip your ecu. However there are a few places that will reprogram an obd2 ecu. Unfortunately no one can reprogram an obd2b ecu. There are plenty of places that you can find chips/programs for your obd1 ecu (jet, skunk2, etc.) I wouldn't recommend any of them as they are generic chips that do not take into account the actual modifications that you have done to your vehicle. If you want to chip your obd1 ecu, then get a custom chip with a program that was created for your vehicle.
How can I reprogram my stock ECU?
OBD2b ecus can not be reprogrammed. This is not a recommendation, but simply a list of resources for reprogramming your ecu.
www.pgmfi.org (look for uberdata) or http://uberdata.pgmfi.org/forum/index.php
www.turboedit.org
What is hondata?
Hondata is one of the many aftermarket engine management systems such as the AEM EMS, Apexi PowerFC, Accel DFI, etc. These are complete engine management systems that can replace your ecu. The hondata is the cheapest, but the others are programmable on the fly via a laptop whereas you have to burn a new chip for the hondata. The downside of hondata is that it requires that you are obd-1, whereas the other systems are available for obd2 vehicles. It is illegal to convert an obd2 vehicle to an obd1 vehicle and depending on your area, they may actually test factory equipped obd2 vehicles by connecting to the obd2 service port, so you will fail inspection if you have converted to obd1.
How is the AFC different from hondata?
The Apexi V-AFC/S-AFC are piggybacks onto the factory ecu. They are used to make fuel adjustments and are often used in mild turbo setups. However the AFC is not able to control the spark which is where it really falls short of hondata and other engine management systems. Also if you have an obd1 vehicle, then go ahead and do it right with hondata. It is not much more expensive than the AFC.
< Message edited by md420 -- 12/5/2005 1:44:54 PM >
Post #: 1
RE: ECU F.A.Q's - 12/9/2005 3:16:47 PM
Marty
Status: offline
quote:
ORIGINAL: 2000Si
As written out by Haynes. There are many many more... just not in Haynes.
OBD I Trouble Codes
Code 0 Faulty PCM
Code 1 Oxygen Content
Code 3-5 Manifold Absolute Pressure (sensor)
Code 4 Crankshaft position sensor (CKP)
Code 6 Coolant Temperature
Code 7 Throttle Angle (TPS)
Code 8 TDC position
Code 9 No. 1 cylinder position (CYP)
Code 10 Intake Air Temperature (IAT)
Code 12 Exhaust Gas Recirculation System
Code 13 Barometric Pressure
Code 14 Idle Air Control (IAC) valve
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor (VSS)
Code 19 Lock-up Control Solenoid
Code 20 Electronic load detector (ELD)
Code 21 Variable Valve Timing and Valve Lift Solenoid - VTEC solenoid check
Code 22 Variable Valve Timing and control pressure switch
Code 23 Knock Sensor
Code 30 A/T FI signal A, (Automatic transmission vehicles)
Code 41 and 48 Oxygen sensor heater
Code 43 Fuel Supply System
OBDII Codes
Code | (CEL flashes) | Probable Cause
P0010 Variable Valve Timing Control (VTC) Oil Control Solenoid Valve Malfunction
P0011 Variable Valve Timing Control (VTC) System Malfunction
P0101 Mass Airflow (MAF) Sensor Range/Performance Problem
P0102 Mass Airflow (MAF) Sensor Circuit Low Voltage
P0103 Mass Airflow (MAF) Sensor Circuit High Voltage
P0106 (5) Manifold Absolute Pressure (MAP) circuit range/perf. problem
P0107 (3) Manifold Absolute Pressure (MAP) sensor low input
P0108 (3) Manifold Absolute Pressure (MAP) sensor high input
P0111 (10) Intake Air Temperature (IAT) circuit range/perf. problem
P0112 (10) Intake Air Temperature (IAT) sensor circuit low input
P0113 (10) Intake Air Temperature (IAT) sensor circuit high input
P0116 (86) Engine Coolant Temperature (ECT) sensor circuit range/perf. problem
P0117 (6) Engine Coolant Temperature (ECT) sensor circuit low input
P0118 (6) Engine Coolant Temperature (ECT) sensor circuit high input
P0122 Throttle Position (TP) Sensor Circuit Low Input
P0123 Throttle Position (TP) Sensor Circuit High Input
P0125 Engine Coolant Temperature (ECT) Sensor Slow Response
P0128 Cooling System Malfunction
P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
P0133 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) Circuit Slow Response
P0134 Air/Fuel Ratio (A/F) Sensor (Sensor 1) No Activity Detected
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0137 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit Low Voltage
P0138 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit High Voltage
P0139 Secondary Heated Oxygen Sensor (Secondary HO2S) Slow Response
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
P0143 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Low Voltage
P0144 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit High Voltage
P0145 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Slow Response
P0147 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Heater Circuit Malfunction
P0153 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Circuit Slow Response
P0154 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater System Malfunction
P0155 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater Circuit Malfunction
P0157 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
Circuit Low Voltage
P0158 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
P0159 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
P0161 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
P0171 Fuel System Too Lean
P0172 Fuel System Too Rich
P0174 Front Bank (Bank 2) Fuel System Too Lean
P0175 Front Bank (Bank 2) Fuel System Too Rich
P0191 Fuel Pressure Sensor Range/Performance Problem
P0192 Fuel Pressure Sensor Circuit Low Voltage
P0193 Fuel Pressure Sensor Circuit High Voltage
P0196 EOT Sensor/Range Performance Problem
P0197 EOT Sensor Circuit Low Voltage
P0198 EOT Sensor Circuit High Voltage
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage
P0300 Random Misfire
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P0303 No. 3 Cylinder Misfire
P0304 No. 4 Cylinder Misfire
P0305 No. 5 Cylinder Misfire
P0306 No. 6 Cylinder Misfire
P0325 Knock Sensor Circuit Malfunction
P0335 Crankshaft Position (CKP) Sensor Circuit No Signal
P0336
P0339
Crankshaft Position (CKP) Sensor Circuit Intermittent Interruption
P0340 Camshaft Position (CMP) Sensor No Signal
P0341 Camshaft Position (CMP) Sensor A Intermittent Interruption
P0341 Variable Valve Timing Control (VTC) Phase Gap
P0344 Camshaft Position (CMP) Sensor Intermittent Interruption
P0365 Camshaft Position (CMP) Sensor B No Signal
P0366
P0369
Camshaft Position (CMP) Sensor B Intermittent Interruption
P0385 Crankshaft Position (CKP) Sensor B No Signal
P0389 Crankshaft Position (CKP) Sensor B Intermittent Interruption
P0401 Exhaust Gas Recirculation (EGR) Insufficient Flow
P0404 Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance Problem
P0406 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
P0410 Air Pump Circuit Malfunction
P0411 Secondary Air Injection System Incorrect Flow
P0420 Catalyst System Efficiency Below Threshold
P0430 Front Bank Catalyst System Efficiency Below Threshold (Bank 2)
P0441 Evaporative Emission (EVAP) Control System Incorrect Purge Flow
P0442 Evaporative Emission (EVAP) System Small Leak Detected
P0443 Evaporative Emission (EVAP) Canister Purge Valve Circuit Malfunction
P0451 Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
P0456 Evaporative Emission (EVAP) System Very Small Leak Detected
P0457 Evaporative Emission (EVAP) System Leak Detected Fuel Fill Cap Loose/Off
P0461 Fuel Gauge Sending Unit Range/Performance Problem
P0462 Fuel Gauge Sending Unit Circuit Low Voltage
P0463 Fuel Gauge Sending Unit Circuit High Voltage
P0496 Evaporative Emission (EVAP) System High Purge Flow
P0497 Evaporative Emission (EVAP) System Low Purge Flow
P0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage
P0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High Voltage
P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
P0501 Vehicle Speed Sensor (VSS) Range/Peformance Problem
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0511 Idle Air Control (IAC) Valve Circuit Malfunction
P0521 EOP Sensor Range/Performance Problem
P0522 EOP Sensor Circuit Low Voltage
P0523 EOP Sensor Circuit High Voltage
P0560 ECM Back-up Circuit Low Voltage
P0563 Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Source Circuit
Unexpected Voltage
P0600 Multiplex Control System Troubleshooting
P0603 ECM/PCM Internal Control Module Keep Alive Memory (KAM) Error
P0606 ECM/PCM Processor Malfunction
P0661 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit Low Voltage
P0662 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit High Voltage
P0685 ECM/PCM Power Relay Control Circuit Malfunction
P0700 Automatic Transmission Control System
P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
P0706 Open in Transmission Range Switch Circuit
(in reply to Marty)
Post #: 2
RE: ECU F.A.Q's - 12/11/2005 7:05:44 PM
97CivicEX
Status: offline
quote:
ORIGINAL: md420
I think the s300 (fairly new from what I can tell) doesn't use eprom chips and can be programmed on the fly.
_____________________________
200,000 miles strong!!!
Black 4 door, WingsWest Racing Series Ground effects, DC 4-1 Headers, AEM CAI,
Edelbrock Performer X Turbo soon to come!
(in reply to Marty)
Post #: 3
RE: ECU F.A.Q's - 12/11/2005 8:57:55 PM
Marty
Status: offline
Good info thanks.
(in reply to 97CivicEX)
Post #: 4
RE: ECU F.A.Q's - 5/15/2006 7:42:33 PM
ShowcaseCivic
Status: offline
ShowcaseCivic's photo gallery
What if you can't even get a code at all? I just bought a 98 civic DX from a guy who had a 99 EX engine swap done so it has the OBD2 ecu but now the scanners won't even link up to the computer so i can't pass emissions. pretty much blows. if anyone can help me out that'd be sweet.
(in reply to Marty)
Post #: 5
RE: ECU F.A.Q's - 6/27/2007 10:54:50 AM
Live4Boost
Status: offline
I have a p28 and an VAFC hooked to it. sould i still chip it?
Life is so much better once you BOOST it.
(in reply to ShowcaseCivic)
Post #: 6
RE: ECU F.A.Q's - 9/9/2007 12:59:35 PM
addiction2bass
Status: online
addiction2bass's photo gallery
my question would be how do you tell if this has been chiped or stock? is thier any visable way to tell? i have a feeling my 94has been changed.... and i just wanna be sure mines not chiped or what not caus ei want it to run right and have the stock programing like mainly the rev limiter!
(in reply to Live4Boost)
Post #: 7
RE: ECU F.A.Q's - 9/10/2007 4:24:05 AM
Forty04
Status: offline
Forty04's photo gallery
Pull the cover off of the ECU, and look inside.
Chipped (Chip/socket is circled)
Stock, same area as circled above, without a chip/socket
Don''''t PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
(in reply to addiction2bass)
Post #: 8
RE: ECU F.A.Q's - 9/10/2007 5:52:09 AM
addiction2bass
Status: online
ok sweet. then i do have a stock computer then... tho i can see its been replaced before... thiers 2 bolts missing from it on the backside on the main bolt down. and the green wire has been taped into before and now is just taped up.
total hackjob i hope i can figure out his unhooked wires!
thanks for your help. so i dont have to worry about over reving the motor...
(in reply to Forty04)
Post #: 9
RE: ECU F.A.Q's - 11/14/2007 4:12:58 PM
Civic Dx 349
Status: offline
I took my Y8(OBD2b) motor out and dropped in a Z6(OBD1) motor. Can I use the Y8 wire harness with the Z6 motor and just switch the ECU's and be fine? Anything else needed or is it just plug in and play??????
-My rides-
1995 Ex
(B18c-R w/ Jackson Racing Super Charger + Goodies)
2000 Ex
(Swapped motor and Up For sale)
1995 Dx
(Daily driver and my first civic w/ goodies)
1995 Ex
(Wrecked with a bent frame)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414235
remmy11161
fiirkan10506
mill$civic8468
marty8273
mxs8006
fliphkd7207711
nail i3unny7705
sacicons7675
addiction2ba7360
New Vendors
K&N Engineering, Inc.
