Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EG Swaps
Reply
Old 12-30-2004, 10:43 AM
maddstylez maddstylez is offline
Default what swap should i do?
ok, i have a 95 civic 1.5..... lame i know.... but what would be the best most cappatable swap i could do, for the hp and functionality?
i want to get a turbo and stuff like that, but is my 1.5 worth it?
__________________
2 audiobahn 12's(special eddition), a 1000 watt 2 chanel pheonix digital amp, and 1000 watt 4 chanel pheonix digital amp,
boss suround speakers, boss head unit.
body kit, from www.razzi.com
18" rims
http://www.cardomain.com/memberpage/774474
Sponsored Links
Old 12-30-2004, 10:46 AM
Default RE: what swap should i do?
and how much hp do i have now? is it 125, i have a good exhaust and an aem intake, maybe some other minors, but im not sure....
__________________
18" rims
Old 12-30-2004, 10:48 AM
will this work in my car....
B18C5 1.8 16V DOHC VTEC PGM-FI 1797 195hp@7800rpm 130tq@7600rpm 98-01 Integra Type-R
__________________
18" rims
Old 12-30-2004, 12:27 PM
niteryder niteryder is offline
it is a little pricey but worth it because it has an lsd( which is always good if u race)
some that will be cheaper but still good are the b18c1, b16b, and b16a
__________________
a vtec a day will keep the doctor away
Old 12-30-2004, 06:37 PM
sacicons sacicons is offline
yeah, and yours has 102 stock. ill give you another 10 for the mods, tops, considering the mileage.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 12-31-2004, 01:19 AM
Kappa22 Kappa22 is offline
If you're going for a turbo engine, I would go with a B18C1 (GSR) engine. It has a lower CR, so it won't require as serious of a reduction to adapt for the turbo. Basically, the only advantage the Type R engine (B18C5) has over the C1 (if you're planning to add a turbo) is the stock LSD. I wouldn't even consider a B16 for turbo applications (unless you plan to tear it down to a drag strip car). Plus, you'll probably save enough on the cost difference between the C5 and the C1 to pay for a turbo kit. Bottom line: Go for a GSR engine. You can always add an LSD later.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 01-22-2005, 10:09 AM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
what does the 92 civic cx 8 valve motor have for hp, it has a cold air intake, ignition wires, pulley, and wires, and exsaust. i havent put her on the dyno though but i am curious i have taken on 16valve manuels and my hood was at there trunk and tehy wernt going nowere. so what do ya think
__________________
non-vtec ALL THE WAY
cylinder head guru!
Old 01-22-2005, 10:59 AM
ummm, 92 hp if i remember correctly. get a 16v. even a d15b7 would be a big improvement. and a 16v will take to mods better than the 8. and you should be able to get a b7 for damn near free, then get an ex tranny and throw it all in there at the same time. it will make a huge difference in your car.
__________________
Quote:
ORIGINAL: Forty04
Old 01-22-2005, 02:21 PM
The stock CX is pushing 70 hp and 91 lb/ft.
__________________
Old 01-22-2005, 10:01 PM
oh yeah, its the vx running 92. my bad.
__________________
Quote:
ORIGINAL: Forty04
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
