Your System??
Old Apr 25, 2004 | 07:17 PM
ImportKid's Avatar
Default Your System??
ok lol u can stop postwhoring the whole forum now<IMG src=smileys/smiley29.gif border="0">
Old Apr 25, 2004 | 07:19 PM
Fierce100's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
lol, im home alone and bored as hell, what am i supposed to do...
Old Apr 26, 2004 | 07:24 AM
iNTRuDeR's Avatar
Mine is still stock which is pretty much OK with me for now.</P>
I've got other stuff I'll spend the money on.</P>
2way radio etc.</P>
But the bottom has such a muddy sound, </P>
what is recommended to just (on a budget) clean up the bass.</P>
I don't need to dim the lights, but I do want a cleaner bass line.</P>
No one I've found has a simple amp/box combo that is worth anything.</P>
JCW has an amp/tube combo, but I'll bet they'll be just as bad as the stock. Or worse !</P>
</P>
Old Apr 27, 2004 | 01:47 PM
outsider's Avatar
<SPAN class=bold>iNTRuDeR-</SPAN></P>
<SPAN class=bold>I would avoid any/all of the "bass tubes" if you want clean sound. They make noise, but not good noise.</SPAN></P>
<SPAN class=bold>as for adding an amp/sub setup to you existing system, I am not sure how to do that. What you could do is buy an aftermarket headunit with preouts to run to an amp. Then get a small monoblock amp and a basic sub. I have no idea what your budget is, so I can't really give many suggestions other than talking to a car audio shop. Many shops have package deals.</SPAN></P>
</P>
Old Apr 27, 2004 | 03:24 PM
iNTRuDeR's Avatar
Good idea,</P>
I tend to avoid the local shops only due to inexperience.</P>
But they are a good source of info.</P>
Yeah, I'd just like it to sound a bit cleaner, but don't have the bugdet for (and don't reallly want) to $pend a bunch to get the real bass,</P>
just cleaner.</P>
</P>
Old Apr 27, 2004 | 07:31 PM
ImportKid's Avatar
get an equalizer
Old Apr 28, 2004 | 01:50 PM
lilol89crx's Avatar
im runnin sum older sony head unit, cheap *** scoche 5.25front door speakers, pioneer 6x8 out back, 700watt lightning audio mono amp, and an old school audiobahn 12" in a 2.8 cube slot ported box tuned to 39.... not much but its enough to shake the table in the house and im happy with it. although the box does weigh a heap.
Old Apr 28, 2004 | 02:06 PM
ghetto ryde's Avatar
Well, I am kinda poor so I still got alot of work to do, so I just have a systems that works... its a kenwood mp3 deck, kenwood 220 wat 3 ways all the way around(4 at 6.5) and I am running a rockford 400 watt punch amp with an alpine typeR 12 inch sub in a closed box. Some day it will all be custome, I promise...
Old Apr 29, 2004 | 03:29 PM
outsider's Avatar
ghetto-</P>
sounds like you've got a good start on your system. It's definitely better than many systems out there.</P>
How does your Type-R sound with 400 watts running it?</P>
Old May 1, 2004 | 09:23 AM
Roentgen's Avatar
outsider is right, everyone has to start off somewhere. Intially, I purchased what I could afford at the time (not very good brands) but I wanted something that was better than stock. Now, I research thoroughly to see what is good and what isn't. </P>
ghetto, seems like you have a nice setup and I can imagine how hard that Type R 12 must hit with 400 watts being powered to it. </P>
</P>
