Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Paint Your Brake Calipers and Drums by mxs
  Printable Version
Honda Civic Forums >> General Automotive >> DIY - Do It Yourself >> Exterior Modification DIYs >> Paint Your Brake Calipers and Drums by mxs Page: [1]
Login
Message << Older Topic   Newer Topic >>
Paint Your Brake Calipers and Drums by mxs - 12/29/2005 2:17:01 AM
mxs
Status: offline
mxs's photo gallery
You will need:
A jack and jackstands
Wire brushes
Masking tape
Caliper paint kit (I used the G2 kit, Duplicolor makes a similar kit), includes:
- 2 part high temperature paint
- mixing stick
- brush
- brake cleaner
Jack up your car, set it securely on the stands, and remove the wheels. I did the rear drums first and then the front calipers.
I my case, I was repainting, so I had a lot of paint to remove first.
If you have to remove paint, you can use the brake cleaner spray to soften it. Then remove it with a utility blade or wire brush.
This took me a while because it kept raining.
Finally, all the paint is stripped off both drums.
If you don't have to remove any paint, just scrub the drums with a wire brush to remove any rust, mud, whatever. Then spray it all down with the brake cleaner. It's important to have a good, clean surface.
Finally, you're ready to paint. Mix the two parts of the paint together according to the directions. Mask off the back of the drum if you want. Then get out the brush and start painting! You don't need to paint the face of the drum where the wheel touches.
Apply two coats, and allow it to dry according to the directions before reinstalling the wheels.
To paint the calipers, follow the same procedure.
Before:
Without the paint:
I did this without removing the calipers. It worked OK. You can also loosen the bolts on the back and swing the caliper up, or remove it completely. If you're going to do it like I did, get masking tape and mask off the rubber dust boots (see above) and the rotors (see below). You do not want to get any paint on the rotors.
Again, apply two coats and allow the paint to dry before reinstalling the wheels.
So here's the before and after:
Now, your eyes focus on the shiny new wheels instead of the chipping paint on the calipers.
The entire project took me about two days, but I had a lot of old paint to remove, I was being super careful, and it kept raining. This was my first modification, it was really easy and made a big difference. I recommend it.
_____________________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10322
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
