At low speeds, I'm hearing a clinking type sound coming from the rear right wheel. It usually happens when turning. The Chilton manual is a lot of help, for troubleshooting it recommends "inspecting the tire for debris", yeah whatever, this is a mechanical noise.
On visual inspection, everything looks tight and connected. Lug nuts are tight. Bad bearing possibly?
Mine does the exact same thing! I'm pretty sure that it's the drum cause it'll do it if I lightly pull the ebrake too. It'll go away and come back every now and then. I pretend like it's not there.[sm=grinangel.gif]
if you speed up or slow down, does the noise speed up or slow down? like something's hitting something as the wheel spins?
__________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
because you're not applying the brakes. I dont think its the turn's fault that you hear the noise, its the brakes being applied through that turn. I could VERY well be wrong tho.
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
