Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EG Swaps
Reply
Old 02-06-2006, 02:38 PM
Djohnsto Djohnsto is offline
Default ZC Swap for 92 Civic HB
Well I want to swap from stock 1.5 SOHC 16v non-vtec out of my car for the ZC 1.6 DOHC non-vtec and build that. I have the need for speed and i figured out that building and turboing the ZC would most likely be cheaper to for-fill my need or want. Will I be able to use the same wire harness and computer in this swap?
__________________
Full Poineer System
Airmass Header
Tusdo Catback Exhaust
B18B(on the way)
SRI
1.5" drop
Sponsored Links
Old 02-06-2006, 07:17 PM
ef4life ef4life is offline
Default RE: ZC Swap for 92 Civic HB
i don't believe there is a dohc zc motor that is obd1.
but if your going to build a good turbo motor you could stick with your 1.5 add new pistons and rods, swap a z6 head on it, wire up vtec, get a p28 and hondata or another engine management system, and then turbo it and enjoy a good relatively cheap build(compared to buying another engine and doing the same)
__________________
Old 02-08-2006, 01:44 PM
Really.....I see on ebay that they have a few of the ZC engines and that are for the 92-95 civic's. That is what brought this swap to my attention. My engine has 160,xxx so id like to swap rather then just doing a mini-turbo.
http://cgi.ebay.com/ebaymotors/JDM-Z...34595998QQrdZ1
__________________
Full Poineer System
Airmass Header
B18B(on the way)
SRI
1.5" drop
Old 02-08-2006, 02:20 PM
well, i guess there is a zc for obd1, and since its non-vtec you should be able to use the same harness, but you will need the zc ecu
__________________
Old 02-08-2006, 02:27 PM
Aight cool...the harness was the only thing i was really worried about.
__________________
Full Poineer System
Airmass Header
B18B(on the way)
SRI
1.5" drop
Old 02-08-2006, 02:45 PM
there might be a little thing to add with the second cam, but i never messed with any dual cam stuff really
__________________
Old 02-10-2006, 09:47 PM
I didnt think the second cam would really have anything to do with computer.
__________________
Full Poineer System
Airmass Header
B18B(on the way)
SRI
1.5" drop
Old 04-17-2006, 12:12 PM
Crook_EG8 Crook_EG8 is offline
i did a ZC into an 89 Si, and got a greddy turbo for it and ProfecII boost controller, i ran a 12.5 @ 1.8 bar of boost, gettin reddy to put that engine in my EG in a few weeks
__________________
Quote:
ORIGINAL: Forty04
Theres really only two seasons here in Michigan, winter, and construction.
Old 04-17-2006, 03:55 PM
Kappa22 Kappa22 is offline
The 92-95 ZC's are identifiable by their brown dizzy plugs.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
