Go Back   HondaCivicForum.com > General Forum Information > New Member Introductions
Reply
Old 02-06-2006, 07:47 PM
yaserkali yaserkali is offline
Default Check out my new Civic...lots 2 do!
IdeaS? Im thinking 17s, 40mm drop - ur ideas?
Also - wana get 12v power from car battery into interiro for blue neon rods - where can I get the wire through?? the whole under the dash with exisitng wires has rubber inside it and real tight - alternatives???
Thanks
__________________
Honda Civic Sport Coupe
Cold Air Intake
6500K super white, blue tinted halogens
Interior Ultra blue neons
Sony ICE
Planned:
Engine Swap or Turbo
Full Cat Back Exhaust
Race Header
16 or 17 inc low profile multi-spok
Sponsored Links
Old 02-06-2006, 08:07 PM
ef4life ef4life is offline
Default RE: Check out my new Civic...lots 2 do!
i like the car a lot, the 40mm seems good, i am not a fan of 17's i think 16 is the max. for the neon idea, you could splice into you cigarette lighter wiring and not have to go through the firewall, but you might overload the circuit if you use a lot of neons and also use the cig lighter at the same time. so you could install larger dia. wire from the fuse block to the lighter and SAFELY install a bigger fuse, without worry of starting a fire.
i mean safely because if you just put a higher amp fuse with small wiring, the current draw could overload the wires and cause a fire, so larger wires can handle more current and a bigger fuse if needed
__________________
Old 02-06-2006, 09:02 PM
00 Ess Eye 00 Ess Eye is offline
drop and 16's would look nice. welcome
__________________
Old 02-06-2006, 10:15 PM
Cutt Cutt is offline
Welcome to HCF. Good luck with your project.
__________________
I was wondering if the forum had a special section for real engines???
Old 02-07-2006, 12:29 AM
riceburner700's Avatar
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
what color rims were you thinking?
__________________
cylinder head guru!
Non Vtec power
Old 02-07-2006, 02:42 AM
97_nw 97_nw is offline
i like that car color..props! welcome.
__________________
Old 02-07-2006, 11:35 AM
mill$civic mill$civic is offline
welcome to the forum!..go with the 17" and drop
__________________
Member since Feb 2005
Old 02-07-2006, 12:13 PM
Toxxic Toxxic is offline
i have an exhaust im trying to get rid of for 200+s/h.
its not a great brand but its almost brand new, check out my f/s thread.
__________________
FS: 92-95 civic parts & crv head.
Old 02-07-2006, 04:45 PM
domestic disturbance domestic disturbance is offline
Welcome, I like the color too...I'd go 16's & the drop.
__________________
2004 Red Civic EX Coupe
SilverStar vision & signals
Old 02-07-2006, 05:36 PM
usmc2b2004 usmc2b2004 is offline
Send a message via AIM to usmc2b2004 Send a message via Yahoo to usmc2b2004
Welcome Yea the colors unique
__________________
Doing my "CIVIC" duty
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
