Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-07-2006, 06:33 PM
Crazed Crazed is offline
Default 17s rubbing in the rear
I put on 17" rims with 210/45/17r tires on my 2000 Civic but the rear tires are rubbing hard when there is any body roll. The auto shop told me to find some rubber coil spring spacers to possible stop the rubbing. Anyone know anything about these spacers and how to pick out the right one. I think maybe 1" lift might fix the problem.
Sponsored Links
Old 02-07-2006, 09:43 PM
SITNLOW97 SITNLOW97 is offline
Send a message via AIM to SITNLOW97
Default RE: 17s rubbing in the rear
how low is ur car?
__________________
Old 02-07-2006, 11:43 PM
It is stock
But I think the back is lower because of the 2 12" subwoofers in the trunk.
Old 02-08-2006, 02:37 AM
psychocivic psychocivic is offline
Send a message via AIM to psychocivic
2 12" shouldn't put the rear down that far. unless the subs and box weighed a few hundred pounds. maybe your shocks/springs are shot?
__________________
Old 02-08-2006, 08:55 AM
The box is huge it barely fits in the trunk and the subs have 20 oz magnets on them each. Idk if I can even fit it out of the trunk, it is that heavy.
I had 40/17r on my 17" rims but the rims got all dented. So I got the 45s and it seems to be rubbing bad.
Old 02-08-2006, 03:09 PM
I took the subs out and it only made about a centimeter difference.
I just need something to give my civic about a 1" lift in the rear anyone know sompelace I can get this?
Old 02-08-2006, 03:13 PM
dj_ipirate dj_ipirate is offline
seems like your springs are shot. it really shouldnt be doing that. some retards are rolling on dubs with no problem.
__________________
nice mustang... sorry about your penis.
Old 02-10-2006, 11:56 PM
95redcivic 95redcivic is offline
I have the same problem on my son's 1995 Honda civic DX coupe. How did you fix the problem?
Old 02-11-2006, 09:21 AM
sam@missionspeed sam@missionspeed is offline
Send a message via AIM to sam@missionspeed
I would have to agree with the above statements about your suspension. If your suspension (either shocks, springs, or both) are worn out, your car will have too much bounce when you hit a bump, or too much roll when you take a turn. Normally that tire size wouldn't cause any problems, especially on a car at stock ride height. Instead of getting spacers to correct the symptoms, I would check into new suspension to fix the problem.
I would also check the offset. If your wheels are sticking out too far, that will cause a problem, especially with a thicker tire like you have (compared to a 205/40/17). That is always something to take into consideration when choosing your tires. Good luck!
__________________
Quote:
ORIGINAL: dj_ipirate
i always thought it had something to do with the name "baker" i thought it was a pic of you baked
Old 02-11-2006, 02:16 PM
I bought some spring boosters from Advanced Auto parts and it seems to have helped a little.
The tires I bought though are actually 215/45HR-17 so they are probobly to wide for my car.
Now it only rubs when I take shape turns fast or a 90 degree turn when there are bumps but atleast my car is drivable.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
