Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 01-22-2005, 02:34 AM
Super Mario Super Mario is offline
Send a message via AIM to Super Mario
Default Car Swaying When turning
When i turn sharp or pull coners a little faster, the car leans to one side or the other. I know it's not bad shocks, I replaced them less than a few months ago. Does a sway bar solve this problem. also, I want to stiffen my suspension, but i don't want to change my shocks, they're brand new, and I don't want it lowered or anything. I want the ride height to stay the same, just stiffer suspension. any help or ideas?! Thanks to all!!!!
__________________
Honda Civic Forum T-Shirts... Want one? PM ME!
Sponsored Links
Old 01-22-2005, 03:06 AM
sacicons sacicons is offline
Default RE: Car Swaying When turning
you said it. sway bars.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 01-22-2005, 11:28 AM
XCM828 XCM828 is offline
and strut bars
__________________
And for all you VTECHers out there: Please Click
HCF Map!
Old 01-22-2005, 12:01 PM
sways first though, youll notice them WAY more.
__________________
Quote:
ORIGINAL: Forty04
Old 01-22-2005, 01:13 PM
polo708 polo708 is offline
Send a message via AIM to polo708
sways will make the biggest difference, also the lower you get it to the ground, the less roll you will have.
I have a very simple setup and I get almost no roll at all. Its like point and go
(lowering springs, sways, and a strut bar)
__________________
-brian
Old 01-23-2005, 09:06 PM
jwsimons jwsimons is offline
the least exspensive thing to try would be poly urathane bushings
__________________
getting there is half the fun, do it yourself
Old 01-23-2005, 10:54 PM
yeah, if you can install them all yourself. believe me, its not easy. and a friend of mine got a quote on his integra, and it was like 600 bucks for the install.
__________________
Quote:
ORIGINAL: Forty04
Old 01-25-2005, 11:34 PM
Anybody got one for sale for a 95 civic dx sedan. how about where i can get one?
Quote:
ORIGINAL: sacicons
__________________
Old 01-26-2005, 12:04 AM
ist his what i'm looking for?!?! I'm pretty sure the brand is trustworthy. Is the price expensive, reasonable, what?!?! I'm pretty sure this is what I need. I can't seem to find too many sway bars for my car!! Help please! if the proce is a little high i'm willing to pay for the quality, I DONOT WANT GARBAGE! This is probably going to be one of my biggest mods yet besides putting in my own system!!! I hat 5 1/2 is the rear and i stripped it and cut out holes for 6x9's and put them in I took them out of a 93 lincoln continental. That's what i used to drive so i know this thing BuMPS!!! Thanks, Josh
http://www.performancecenter.com/pro...oductID=366405
__________________
Old 01-26-2005, 12:40 AM
slvcivic00 slvcivic00 is offline
Sway bars are all basically the same and do the same thing. The more expensive sway bars usually are made of a lighter material to save weight. And if you are woried about saving a couple of ounces then go buy an expensive one. But you can find ones for as cheap as $20 or $30 like the ones on www.makotoautotrends.com they are still fairly rigid and will get the job done. As far as springs go, H&R springs have a type of spring set that are called OEM springs that stiffen you ride up and still mantain your stock height. And you can still keep your shocks you have in your car now.
__________________
The magic starts at 5500 RPM!
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
