Alright, I'm a newbie when it comes to honda engines... My head gasket went monday, and I'm debating what to do. I dont want to do the head b/c it has 217k on the engine... I dont have that much money to do an all out swap, or time for that matter, to swap in the engine I got with the car. I was wondering what my best route is to go on that. I have a d15b8 currently, in a 95 cx hatch. I was thinkin of maybe the d15b vtech swap. If anyone could tell me exactly what that would entail.. or if i'd be best to just replace the stock engine. My uncle claims that he can get a b20b?? I guess an engine out of a crv. and says that it will directly bolt and plug in to everything there with no mods. I find that hard to believe. But any help would be greatly appreciated. Thank you.
__________________
95 cx hatch...
c.a.i.
mc-s header
no cat
2.5" piping from header back
some sort of 5" muffler...
short throw shifter
Mini-me swap with z6 head & intake and y8 gasket (middle section removed)
Street Imports z6 distributor
ngk plugs
Welcome for the if moneys an issue you should consider a "mini-me" swap. That consist of putting a d16 head on your d15 block all you need is the head maniflods and ECU. And have at it!
Is there any particular b16 head... or just any in general... And would I need the whole wiring harness? I already have the header that would bolt up to that head. The only question that I have, would that be logical on an engine with 217,000? And about how much would it run?
__________________
95 cx hatch...
c.a.i.
mc-s header
no cat
short throw shifter
ngk plugs
Yea well you'll need a OBDI head and get the ECU from the same car you get the head from and you'll have to wire V-Tecbut its not that hard. But price wise depending on where you go around 150-200 well thats what it would cost me.
mmm...actually a mini-me is putting a SOHC vtec head on an engine that was originally SOHC non-vtec.
The motor has 217K miles on it. If your gonna go to the trouble of doing a mini-me swap and want some power, maybe it is a good idea to rebuild the motor. But you don't have time or money. I don' think a rebuild should be more than like 1k but i've never done it before. I'm pretty sure its gonna be time consuming especially if its your first one.
