Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-14-2006, 01:07 PM
2002coupe 2002coupe is offline
Default Need help about tire size???
I just bouth some 17" wheels for my 2002 civic coupe and I was wondering if my tires were the right size ?I got some 215/40R17/.
Sponsored Links
Old 02-18-2006, 02:41 AM
95CIVICUS 95CIVICUS is offline
Default RE: Need help about tire size???
what is the width of the rim? is it 7", 7.5" or 8"
if it is 7 you will ned 205/40/17
if it is 7.5 you will nedd 215/40/17
if it is 8 you will nedd 225/40/17
Old 02-18-2006, 02:44 AM
neon3kgt neon3kgt is offline
Send a message via AIM to neon3kgt
i would go with 205/40... anything wider and you have a chance of rubbing.
Old 02-18-2006, 03:07 AM
NTX NTX is offline
moved to tires and wheels
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 02-21-2006, 08:29 PM
TorGa3iGhT TorGa3iGhT is offline
I believe 7th gen civics have a larger wheel well, so you may be able to go with 215/45...stll depends on what kind of drop you are looking at though...you MAY run into rubbing issues...i'd check out 7thgencivic.com. they have a lot of specific information about your civic that you may find useful
__________________
Old 02-22-2006, 02:12 PM
baker baker is offline
Send a message via AIM to baker
__________________
92 Hatch: B18B POS in progress
Honda Tech Has No Tech
MY FOR SALE THREAD
Old 02-22-2006, 09:52 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
i would just go with the 215/40r17's that you have, they will work just fine
__________________
cylinder head guru!
Non Vtec power
Old 02-23-2006, 07:16 PM
Ok thank's guys !!How could I post a picture of my rims and tire ??I would like to get your opinions
Old 02-27-2006, 11:04 AM
KarTuneMan KarTuneMan is offline
Look on the back side of the wheel....there will be some info there that is VERY important. Size (17x7.5) and offset (+40mm) Its hard to imagine that a couple of mm could/would make a diff. The offset is the key. If the wheel is 7.5 wide the offset you need is NO LESS than +42mm. If the wheel is 7.0 wide you can maybe get away with a +40, NO LESS than +38, or they will hang out too far. Ideal for your civic (fits just like stocks) is 17x7 +45mm. You can lower the car as far as you want. (within reason of course)
__________________
Quit your complaining, if your stupid..... your stupid.
It's not MY fault! Blame your parents.
Old 02-27-2006, 08:06 PM
OK thanks .My rims are 17x7 with a 40mm offset . What to you think ?
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
