Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 02-16-2006, 06:03 PM
MccM MccM is offline
Default Supercharger or Turbo?
Which would you reccomend for a daily driver that is just going to be used for the occasional race probly not going to be taken to the track.
Which is easier to install?
What is the gas milleage like with both?
What sort of price would i be looking at for both?
Thanks
__________________
JDM is the equivalent of emo in the car world.
Sponsored Links
Old 02-16-2006, 07:39 PM
polo708 polo708 is offline
Send a message via AIM to polo708
Default RE: Supercharger or Turbo?
Which would I recommend... usually this will be a biased opinion. people who have turbo's will say turbo and people with superchargers will say supercharger. People with neither will just hop on the turbo bandwagon because they dont know any better. There were no superchargers on the newest fast and furious so people dont care for them. I have had both and can honestly say I like the feel of my supercharged car better. My turbo'd civic was indeed ALOT more powerful, but the low end grunt and pickup of my currently supercharger car is just plain fun to drive. It has pull like a beast and can break traction whenever I want it too... even in a high RPM 4th gear. There's no lag, no cool down to worry about afterwards, no oil lines that need to be run and later leak... just a mounted blower and some fuel control.
ease of installation will go to the supercharger definately.
Gas mileage will be pretty similar, neither has an advantage here.
Price wise... about $3000-$3500 will be your standard price for a basic setup installed, nothing fancy.
Turbos have the advantage of overall potential. The s/c is limited to the pulley size as a means for increasing boost where as a turbo has quite a few ways of making more power. Turbos are often intercooled and roots style blowers are rarely... due to the fact that it directly replaces the manifold. It can be done but its alot of custom work and most companies dont mass produce them. A supercharger offers overall reliability... its just so simple stupid that is hard to mess up. Turbos rely on too many factors for controlling boost and boost creep is a possibility. Also, oil lines have a tendancy to lean and/or break... a supercharger (roots) is simply the manifold and a fuel control system.
__________________
-brian
Old 02-16-2006, 08:19 PM
Street Sniper Street Sniper is offline
Quote:
ORIGINAL: polo708
+1
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 02-16-2006, 09:17 PM
was the 3000 you mentioned for a supercharger or turbo? oh and sorry about posting this in the wrong section i guess i clicked the wrong one. Thanks for the great input
__________________
Old 02-17-2006, 09:59 AM
Pete Pete is offline
Send a message via Yahoo to Pete
It really depends on what your goals are, and your budget. I got a turbo kit for 1300 bucks, but if I found a supercharger for a deal, i woulda got that instead. Ive never driven a supercharged car, so I cant really say. However, installing my turbo wasnt too hard, and my car is a lot faster than it was, and its a blast to drive. If youre looking to make insane power numbers, a turbo setup would be best for you, as you can build the engine and simply turn up the boost with a good tune, superchargers can only go so far. It really depends on what your goal for your power is.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 02-17-2006, 10:10 AM
mxs's Avatar
mxs mxs is offline
Administrator
Quote:
ORIGINAL: MccM
I fixed it for you
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 02-17-2006, 11:20 AM
Remmy Remmy is offline
Administrator
Quote:
ORIGINAL: polo708
like + infinity
__________________
Old 02-17-2006, 01:44 PM
amg6975's Avatar
amg6975 amg6975 is offline
Quote:
ORIGINAL: Remmy
Quote:
ORIGINAL: polo708
like + infinity
Haha.
If you have the money and don't want massive amounts of hp, go with the supercharger.
__________________
Old 02-17-2006, 01:56 PM
well, unless you want to start breaking into the internals then the turbo really doesnt have an advantage over the supercharger. They both will be limited by the strength of your motor. If you are the kinda guy who wants to buy stronger rods and such and are planning on putting 300+ horsepower to the wheels then defiantely go the turbo route because the roots style supercharger (which is what Jackson Racing uses) wont get you there. Now a centrifugal supercharger is a different story... you can get alot more boost out of it, but im pretty sure there are no centrifugal kits for Hondas.
And many people argue that the supercharger uses power to make power because it strains the pulley system... this is true, but a turbo system uses power also. A turbo is an obstruction in the exhaust system which interupts flow and an intercooler uses power to make power also so its kinda one for one again. Without an intercooler you might be running say 6 psi... if you add an intercooler to that setup the IC will be an obstruction and will probably only put out about 4 psi of boost causing you to increase boost to say 8 psi, just to get back up to the origional 6 psi you were at before adding an IC. So it all cost horsepower int he end.
Basically, its all in where you want your power to be seen in the powerband.
__________________
-brian
Old 02-17-2006, 06:04 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
Quote:
ORIGINAL: polo708
vortech does.
http://www.superchargersonline.com/p...=superchargers
i think this thread should be put on the record of HCF history. this is the first SC/TC thread thats gone more than 5 posts that hasnt erupted into a violent and bloody flame war.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
