Go Back   HondaCivicForum.com > Misc. > Motorsports/Racing > Street n Strip
Reply
Old 02-22-2006, 01:52 PM
mill$civic mill$civic is offline
Default what does pre load mean? when racing
hey, when people race i sometimes here that people pre-load because the light turns grean...what does this mean??
__________________
Member since Feb 2005
Sponsored Links
Old 02-22-2006, 01:58 PM
Patrick Patrick is offline
Administrator
Default RE: what does pre load mean? when racing
preloading...for instance, my track car is an automatic trans with a 4000 stall convertor...meaning that as the engine RPM increases, the torque convertor wont actually turn the transmission until 4000rpm..this allows me to launch well into my peak RPM range...this is pre-loading...
it is basically bringint the RPMs up prior to launching...as opposed to launching from idle when the light turns green.
__________________
Old 02-22-2006, 01:59 PM
C5SpoonEG C5SpoonEG is offline
or pre loading the clutch
__________________
All motor B18C5
Bottles are for babies.
Old 02-22-2006, 02:00 PM
Kappa22 Kappa22 is offline
It simply means overtightening your springs/shocks to provide you with a stiffer suspension base, which reduces body pitch on launching. Preload is only temporary, however, and will wear off after a period of time.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-22-2006, 02:49 PM
Forty04 Forty04 is offline
Administrator
three varied responses within 2 minutes of the original question
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Old 02-22-2006, 08:44 PM
sacicons sacicons is offline
and all correct, though i get the feeling that C5 was closer to what was meant in the original question. pre-loading a clutch means you let the clutch out a little so that it is just starting to grip, then you use the handbrake to hold the car from moving. then when the lights drop, your flywheel/clutch/pressure plate are already contacting each other a little, so you dont shock the drivetrain/tires as much when you launch, and you drop the handbrake as you launch. it is a little easier on your drivetrain, and a lot better for getting you off the line without as much wheelspin.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 02-23-2006, 01:49 AM
amg6975's Avatar
amg6975 amg6975 is offline
Interesting, I've never heard of being able to do this with anything other than an automatic RWD car. How I've seen it done is holding the brake and getting the engine going so the rear end squats down so the weight is already shifted back there when you take off.
It makes sence that it would help on FWD too, and it can't be that different than an auto to do it with a manual.
__________________
Old 02-23-2006, 01:53 AM
The method C5 and sacs described is how you should start going if you happen to park or stop facing up a hill to prevent riding the clutch.
__________________
Old 02-23-2006, 01:30 PM
ahhhh ic ic..i get what everyone means, and ^yes i no sometimes when im on a steep hill and theres a stop light, i need to let out my clutch just enoph so my car dosent stall and then after when i hit the gas its keeps me still instead of rolling back a bit
__________________
Old 02-23-2006, 03:34 PM
Administrator
i thought that we were talking about racing...?
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
