Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 02-22-2006, 09:58 PM
91CivicMan 91CivicMan is offline
Default Motor swap b16 or ZC or H23
I have a 1991 honda civic sedan with a y7 motor and im wanting to upgrade should i go with the h23, b16, ZC? Could ya let me know the pros and cons
Sponsored Links
Old 02-23-2006, 06:41 AM
yorky yorky is offline
Default RE: Motor swap b16 or ZC or H23
i got an 88 sedan and i want a zc but they hardly make any performance parts for that engine.b16 s are way more powerful but require more mods to fit.i bought the honda engine swap guide so i can do alot of research.
__________________
88 4 door act street clutch
Old 02-23-2006, 09:14 AM
usmc2b2004 usmc2b2004 is offline
Send a message via AIM to usmc2b2004 Send a message via Yahoo to usmc2b2004
Its hard to find an OBD0 b16 you could put a OBDI with alot of wiring but its possible.
__________________
Doing my "CIVIC" duty
Old 02-23-2006, 09:54 AM
Would the H23 be to big to fit in that car or wut bout a ls motor???
Old 02-23-2006, 10:55 PM
ef4life ef4life is offline
an h series is a big project that involves a lot of cutting and welding and that is for a bolt in mount kit.
b series a a relatively easy swap, and rewireing to obd 1 is not too hard, its just a matter of buying a conversion harness from someone like www.jkobd.com www.boomslang.us or www.rywire.com
__________________
Old 02-24-2006, 02:59 AM
Kappa22 Kappa22 is offline
It doesn't necessarily involve a LOT of cutting, but it does involve some... at least for an H22. I have yet to do an H23.
The SIR-I B16A is a 4G motor, so you wouldn't have a problem there.
And there's plenty of aftermarket support for ZC motors... All they are are D-series'.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 02-24-2006, 06:13 AM
dude what are you talking about? ive never seen any zc parts.you know a site post it.
__________________
Old 02-24-2006, 01:09 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
hahaha damn zc parts are evewhere if you know what to look for. crower/delta offers cams, bottom end parts are compatable with almost all sohc 1.6 bottom ends, you can find everything for a zc that you can find for a sohc 1.6. you will however never find parts listed as "zc" parts. mix and match and you can build your zc.
__________________
Old 02-24-2006, 04:27 PM
what types of engines share these parts.this is a deciding factor of which engine i wanna get.i want the zc becuuse its cheap and easy to install ,but the b16 is way more powerful and has tons of aftermarket support.i want to swap myself because labor is just too expensive.
__________________
Old 02-24-2006, 06:14 PM
from my understanding, the zc uses the same rods as a d16, i believe the pistons might be different though
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
