Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 05-11-2004, 06:25 PM
RuFF RuFF is offline
My Garage
Default Starter Problem
I just bout a 1994 Civic EX 1.6 Sohc with 130,000 miles 5 Speed for $800. Guy told me it needed a new started I popped the clutch to get it started and brought it to my friends to start fixing the car. Find out that it seems he put the wrong starter and the cam wasnt reaching the fly wheel so we find the longer peice flywheel. Guy tolds us it most likely the car orginally fron Cali if it needs this type of starter. Put it in still isnt starting. the teeth on the fly wheel appear it find wit no teeth missing at all. We cant figure out WTF is wrong with it. would anyone have any helpful suggestion???????? <edited><editID>RuFF</editID><editDate>38118.7686689815</editDate></edited>
Sponsored Links
Old 05-11-2004, 07:40 PM
NTX NTX is offline
My Garage
If you are 100% sure the flywheel is good (pull the started out and look at it to make sure the teeth are not worn), i would take the starter out and get a friend to turn the key to be sure the starter solanoid is good. If it does not move out on the shaft when the key is turned, you need to replace it. If the starter is not a Civic starter, ditch it.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 05-11-2004, 07:50 PM
My Garage
my friend thinks it is the flywheel but his father looked at it also and thinks the flywheel is fine. it really apears to be nothing wrong but if there slightly worn would that cause not to start up at all</P>
</P>
ill check that in about an hr</P><edited><editID>RuFF</editID><editDate>38118.8290509259</editDate></edited>
Old 05-11-2004, 08:07 PM
NTX NTX is offline
My Garage
If the teeth are slightly worn, that could be the problem. A sticky solanoid could also be the problem.</P>
When you try to start it, do you hear the starter spinning?</P>
__________________
Old 05-11-2004, 08:14 PM
My Garage
yea the starter is spinning</P>
problem is the car not wit me im going back to it in bout an hr to see if solaniod is the problem.</P>
flywheel looks good to me and his father agreed. really doesnt look worn</P>
Old 05-11-2004, 08:18 PM
NTX NTX is offline
My Garage
Myguess is the solanoid (if the starter is the right one for the car).
__________________
Old 05-16-2004, 12:56 PM
My Garage
turned out that the flywheel would probably broken and they welded using brass. Idiots...
Old 05-16-2004, 02:59 PM
NTX NTX is offline
My Garage
At least now you know and you can start it without having to pop the clutch all the time (unless you want to).
__________________
Old 05-16-2004, 05:06 PM
Importman04 Importman04 is offline
My Garage
i had to do that when i had my 88 hatchback pop the cluth all the time
__________________
When you pull up to a Domestic you lean out the window a say "You wanna VTEC"
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
