Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 03-03-2006, 10:25 PM
88civicjordan 88civicjordan is offline
My Garage
Default y8 or z6 head
I want to do a mini me on my d15b7 but witch head should i use to do it i looked at the info on the z6 head. Is it the same swap for the y8? Same belts etc? with witch one will i obtaine optimal preformance?
Sponsored Links
Old 03-03-2006, 11:18 PM
Street Sniper Street Sniper is offline
My Garage
Default RE: y8 or z6 head
It depends. If you plan on going turbo later then the z6 would be a better choice, but for now and N/A the y8 is better. The y8's combustion chamber is smaller and the result is about a half a point of compression and that half of a point will give you a little more performance right now. Also, the ports are a little different. The z6's are what's called "tumble" ports and give a little better top end. The y8 ports are "swirl" ports and are better down low; but that's getting picky.
Basically, go with what's easier or cheaper.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 03-04-2006, 02:15 PM
Kappa22 Kappa22 is offline
My Garage
Well put.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 03-04-2006, 05:45 PM
natecivic92 natecivic92 is offline
My Garage
Send a message via Yahoo to natecivic92
Is the p28 ecu work for both.
__________________
Old 03-04-2006, 08:22 PM
My Garage
Oh yeah, I forgot to mention that the p28 will work for both, and you will need the y8 cam gear for either, and either timing belt will work as the y8 and the z6 timing belts have the same # of teeth.
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
