Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 03-14-2006, 05:30 AM
w8lifter21 w8lifter21 is offline
My Garage
Default Boost a D15A2, bad idea?
I've posted this on various forums, just seeing what different people's input is. I've got 180k on the clock, but am getting ready to do a full tune up with new gaskets, various oil seals, and a new OEM clutch. I haven't done a compression test yet, but if the cylinders are past 5%ish of each other, that answers my question . I'm just looking for a little more power for scooting around town. Won't be going to the track, the most extreme situation would be some highway driving. Would a S-AFC be ok for me to use with my applicaton? What's the max boost that I should not go past? I know the D15 has weaker internals than the D16, so I would imagine 3-5psi max? Everything will be stock except for an exhaust and maybe a Skunk 2 cam gear.
Sponsored Links
Old 03-14-2006, 12:12 PM
My Garage
Default RE: Boost a D15B2, bad idea?
I made a mistake, I have a D15B2 not a D15A2. My motor has only the two fuel injectors on top. Would an OEM honda headgasket be ok? I don't think I would run more than 5psi. I looked into chipping my ECU, but it is very confusing to me. How exactly is my ecu chipped and how do I run a program like TurboEdit, chrome, or uber?
Old 03-14-2006, 12:28 PM
ef4life ef4life is offline
My Garage
since your car is dpfi (dual ponit fuel injection) you need to convert it to mpfi (multi point) to get more power and a tunable ecu to work with. when you do that you could boost fine up to 7 psi with a good tune, intercooler, and good gas.
__________________
Old 03-14-2006, 02:36 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
yeah so basicly just convert to obd1 lot of tuning options and power can be made rather than obd0
__________________
cylinder head guru!
Non Vtec power
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
