Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 03-15-2006, 05:28 PM
Honda_man Honda_man is offline
Default d series questions
Is it true that the d series in the 96-00 are prone to throwing rods? are they prone to any certain problems?
what about the d series found in the 7th gens? any problems? (reliability wise)
I know neither make good power....but ive heard some things on here recently that make me wonder about the d's and whether or not I should get one with high miles...
__________________
f/s-85 Ford Bronco
-lifted, 31" tires, grill, push bar
-351 W, 117 K, black
-90 Dodge Dakota
-30" tires, grill gaurd, roll bar
-180 K, white
BOTH RUN GREAT, AUTO W/ PWR WIN/LOCK, SOME RUST
Want-02-up Si Hatch, low miles
Sponsored Links
Old 03-15-2006, 05:34 PM
ef4life ef4life is offline
Default RE: d series questions
the d17's are known to bit a bit fragile under boost, but a d16y8 is a good engine to build edlebrock makes a nice bolt on turbo kit for it
__________________
Old 03-15-2006, 05:45 PM
Street Sniper Street Sniper is offline
It is true that the rods are the weak point in the D, but they are still good to 200Hp and/or 7200rpm.
If you are that worried about them and dont want to spring for aftermarket rods, you could just get them shotpeened. Shotpeening increases strength by 100% and it's only like 5 bucks per.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 03-15-2006, 05:56 PM
thanks guys.... im not too worried. most honda motors are awesome(comparatively to other companies) I'm not gonna do to much to it.... if i do, i'll most definately go all motor. (bigger pistons, forged rods, cam, etc.,) but i doubt thatll happen anyways...
guess i just got a little worried, b/c i heard a few ppl bashin the D. oh well. Thanks.
BTW- who would "shotpeen" my rods? what does that even mean? my g/f's dad might be able to do it at his shop....
__________________
f/s-85 Ford Bronco
-90 Dodge Dakota
-180 K, white
Old 03-15-2006, 06:02 PM
Shotpeening id kinda like sandblasting, but it's done with like plastic pellets. Machine shops ought to be able to do it. What it does is smooth out all of the imperfections that might cause weak points.
__________________
Old 03-15-2006, 06:35 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
biggest problem ive heard out of the y7 and y8 is the oil pumps going out prematurly. my y7 did this to me with less than 100k on it. im personally a d-series fanatic although i do drive b-series swapped cars also. there easy to build and parts are everywhere for a decent price.
__________________
Old 03-15-2006, 06:41 PM
antrmo antrmo is offline
yay i read the rod stroke ratio is not so good on the y7. meaning the pressure the piston pushes on the cylider walls a little more than other honda engines,, compared to some thin like the engines in the r types which have amazing R/S ratios,, thats y they redline at 8000
__________________
Nothin kike a 15 hour drive to let u know how your suspension is doing.
96 HB
Ya that silly wing is off now
Does it look like there are many TRACKS in my Area?
Old 03-16-2006, 11:40 AM
interesting... how easy is a b series swap? motor, trans, ecu, mounts? what else? how much? I could look else where... but im feelin lazy
__________________
f/s-85 Ford Bronco
-90 Dodge Dakota
-180 K, white
Old 03-16-2006, 12:31 PM
Quote:
ORIGINAL: antrmo
this is with all 1.6 d-series engines. the 1.5 is a little better but not by much imo. although you can build a hybrid sohc with a better r/s ratio than the type r with just factory parts.
__________________
Old 03-16-2006, 02:43 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
you can get your rods polished too to remove the seam inthem from the forging and causes weakenesses too...but im pretty sure its a lot more expensive than shot peening.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
